Question about Delphi Roady SA10035 XM Radio Receiver
Antenna connection I used to have to turn the antenna at the connection to the unit to get a signal connection. This issue grew into a larger problem when the connection was harder to make. Now I can't get any connection from the antenna, my unit just says antenna all the time. Is there any way to fix this issue or is there a replacement antenna on the market?
  • Anonymous Jan 22, 2008
    My sister is currently experienceing the same issue. We each bought our Roadys around the same time as you must have (a few years ago). Mine still works, but definitely flakes out sometimes. Hers shows the same "ANTENNA" issue as yours, about 90% of the time. I just purchased a new antenna from eBay yesterday. I have not been able to debug the problem, but I thought it was worth the $15 investment to try it out.
  • Old Fiddler Apr 12, 2008
    I have experienced the same problem and it's driving me nuts. I've become addicted to my satelite radio, and my wife doesn't like me driving down the road messing around with the antenna connection in an effort to get a connedtion. I have had my Roady about 1 year, and up until recently have had no problem with it. It is no getting almost impossible to get any thing but the "Antenna" warning on the screen.
Check to see if the center pin in the antenna jack on the radio is bent or missing. I have a Roady II and that is the problem with mine. You may need a magnifing glass to see it.
Posted on Nov 17, 2008
Don't understand why local channels no signal it is not storming
Do you have an internal or external antenna? Does you have an signal amplifier, signal splitter or switch connected?
If the TV was previously connected to this antenna and received multiple channels, check the orientation. External antennas can turn under some conditions. With digital (ATSC) signals, this can be a significant issue, as the tuner may not see enough of the signal.
If there was an powered amplifier attached, check if the unit is getting power. Next check if the signal improves when the amplifier, switch or splitter is removed. In my house, usually only a few channels will be initially blocked by a faulty amplifier. In that case, the amplifier turned into a signal filter for a section of the VHF range. Replace the amplifier or switch if it faulty. If you are using a switch, try an amplifier/splitter that will limit the signal attenuation.
Use www.antennaweb.org or www.tvfool.com to check if where the antenna should point. Antennaweb.org assumes an external antenna and gives very conservative channel lists.
If the problem persists, check if another TV tuner works when connected to the antenna. You could connect a tuner box between the TV and the antenna as a solution. Tuners vary in signal strength sensitivity. Alternatively, replace the TV or the input board with the tuner. (If the TV is under warranty, contact the manufacturer. However, for most small TVs (under <32"), the repair costs are not worth the effort. Sites like www.shopjimmy.com can tell you if parts are available - this site specializes in parts from TVs that were damaged in shipping.)
I hope this helps.
May 24, 2018 | Televison & Video
Is there a antenna or a booster that i can use in the house
There are many antenna systems available for Off-the-Air broadcast TV. It depends on space available mainly. There are internal (inside the home) and external mounted systems. Some external antenna can be mounted in the attic as well. External antenna are usually larger and cable of receiving signals from longer distances. They are either directional (point in one general direction at a time) ir omni directional (can receive signals from 360 degrees without physically aiming or pointing the antenna). They also can come with amplifiers/signal boosters, motors (to rotate the antenna for better recepton without manuall shifting it yourself). You can add splitters ti provide signals to more than one TV at a time. The number if channels you receive can depend on many variables so, depending on your location, how far away from the broadcasting antennae you are, and how you mount your antenna, the number of channels & quality of receive signals will vary.
Good news is there are websites on the Internet that can help immensely, so you don't to hire an electrical engineer!
Apr 25, 2017 | Televison & Video
I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
Feb 26, 2015 | Televison & Video
Radio shows antenna not deteted or acquiring signal but does not work . antenna and all connections are good, ??
The problem is likely the actual connection inside the Starmate. It sounds like you have tried alternate antennas, which can only mean the unit itself has an issue. What has likely happened is the antenna jack inside the radio has come loose and is no longer making a connection, in which case it could be repairable. Otherwise there are plenty of other 12v Sirius receivers compatible with the same connections if you are looking to replace the head unit.
Jun 08, 2011 | Sirius Satellite Radio Sirius Starmate ST1...
Which antenna can be used for sony trinitron
Hello
for Tvs have larger viewing areas, yagi outdoor antenna is the best. With a telescopic indorr antena, although it will work, but there will be some snow in picture, and some interferance, which will be noticable with large screens. Moreover yagi antenna is best for good signal strength and choose an antenna which ahs larger number of cross bars, as it will rise the strength of signal as well as clarity of the picture. Ok
Dec 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    Interference problem on my wireless magic sing, i can hear the voice of my neighbor using her own wireless magic sing on my sound system and vice-versa, it's annoying. what should i do?
    The magic sing has an omnidirectional antenna which is unnecessary since you will be standing directly in front of it while using it. I recommend you take an aluminum pie plate or other aluminum piece that is larger than the antenna and place it directly behind it, perhaps even held on by tape to the antenna. You can even bend it around the antenna in the form of a V with the opening towards you, where you'll be holding the mic. This will block the other signals from your neighbor while still allow you to use it. It may even block your signals from leaking onto your neighbor's unit.
    Jan 23, 2010 | Magic Sing Along Consumer Microphone
    After installing the receiver box I can only get some of the channels. CH 7 is one that I cannot get and I used to get it all the time before installing the box?
    In some situations, DTV signals can be more difficult to tune in. In your location you may need a larger antenna to tune in the digital channels. If you are using and indoor antenna, you may need to relocate the antenna near an outside wall or window or you may need an amplified antenna. If you are connected to and outdoor antenna, adjusting the direction it is aiming may help or in some cases you may need a larger antenna. Visit the AntennaWeb website (http://www.antennaweb.org/aw/Welcome.aspx) for information about the stations you should be receiving and the type of antenna you need.
    Jun 20, 2009 | Televison & Video
    Antenna Connection Problem
    I have the same exact problem. I took a small needle nose pliers and pressed the antenna connection on the TAO radio. I put it back into the cradle of my Altec Lansing amplified speakers. It works again. For how long we will see.
    Sep 05, 2008 | Tao XM2go Satellite Radio Receiver
    Bought ilo without manual
    You need an antenna, satellite, or cable source. If using an antenna, you must then go to the menu and select scan digital channels.
    If nothing comes up, you may need to reposition your antenna and try again, or get a larger antenna.
    May 24, 2008 | iLO 3200 32 in. LCD Television
    Delphi Roady SA10035 XM Radio Receiver Logo
    198 people viewed this question
    Top Delphi Audio Players & Recorders Experts
    Darrell
    xxxxxx xxx
    Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
