Question about Dometic RM2652 Refrigerator
My RM 2652 when dry camping it uses the 2 batteries overnight ?
It works great on 110volts then as soon as i disconect from power it works fine however it uses the batteries up in 24 hours .
I thought it was designed to run on propane so why is it using all that battery power?
Am I meant to turn something off ?
I have been on lots of trips trying to find out what is using the battery
doing the spark to fuse test ,it's definitely the refrigerator taking the power.
Surely it was not meant to do that? Help anyone
  • alan_derber Nov 18, 2008
    I have not been leveling the vehicle ata ll , could this use the battery power trying to keep starting the fridge
    throughout the night ?
    however the fridge auto light stays on all the time ?& stays cold as it should
    We also smelled a very bad amonia smell one day in the cabin one morning ?
    The other problem we get is a very strong smell of bad food , when the food is not bad at all
    dosn;t go away?
    it dosn't smell when the fridge is working but empty?
    It seems to use the food to get the smell , Strange happenings?
    Problem Solver:
  • 19 Answers
OPERATING MODES
AUTO MODE
Press the AUTO/MANUAL mode selector button (2) to the DOWN position. The AUTO mode indicator lamp
(A) will illuminate.
When operating in the AUTO mode, the AUTO mode indicator lamp (A) will illuminate. The control system
will automatically select between AC and GAS operation with AC having priority over GAS. If the control
system is operating on AC energy and it then becomes unavailable, the system will automatically switch to
GAS. As soon as AC becomes available again the control will switch back to AC operation.
If 120 volts AC is not available, the control system will automatically switch to GAS operation. Within 45
seconds the burner should be ignited and operating normally. If unsuccessful, the CHECK indicator lamp (B)
will illuminate.
To restart an ignition attempt with the CHECK lamp illuminated or to clear (turn off) the CHECK lamp, press
the main power ON/OFF button to the OFF and then to the ON position. The control system will attempt a
new 45 second ignition sequence.
On the initial refrigerator start-up on gas (120 volts AC is not available), it may take longer than 45 seconds
to allow air to be purged from the gas line. If the refrigerator has not been used for a long time or the LP tanks
have just been refilled, air may be trapped in the supply lines. To purge the air from the lines may require
resetting the main power ON/OFF button (1) three of four times. If repeated attempts fail to start the LP gas
operation, check to make sure that the LP gas supply tanks are not empty and all manual shutoff valves in
the lines are open.
NOTE: DO NOT continue to reset GAS operation if the CHECK indicator lamp continues to be illuminated
after 3 or 4 tries.
Posted on Nov 18, 2008
What is solar camping gear?
Solarcamping gear is a great environmental solution that allows campers to use thenatural sun to power camping equipment instead of needing batteries foreverything. You can get solar spot lights, battery chargers, generators, andeven solar showers.
Aug 02, 2012 | Camping, Backpacking & Hiking
The refrigerator is not getting power. The plug checked out good as well as the fuses with the volt meter. It is a domestic rm 2652 camper refrigerator.
If all the electrical components are fine then it has to be the motor for the refrigerator. It may be seized or burnt out...therefore it will not work and will need to be replaced.
Oct 12, 2011 | Electronics - Others
RM 2652 RV refrigerator runs on gas, not on AC. Power surge took out power converter and refrigerator power module. Replaced converter and power module. All display panel lights working. Cools great on...
just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
Mar 21, 2011 | Dometic RM2652 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
My cell phone fell into water bucket for five minutes
DO NOT USE HEAT. You will damage the tiny components of your phone.
The best thing to do is that the moment you get water in your phone, disassemble it. Remove the battery as soon as possible. this is very important. Then, open the casing and seperate whatever you can, like the memory card, the back cover, the keypad etc. Shake out any water that you can from the openings. When you shake it you will most probably get some water out.
Now, use a dry cloth to dry your phone. Dry as much as you can.
Next, take a bowl and fill it with dry, uncooked rice. Yes, rice. :) Put your unassembled cellphone in this bowl. All of its parts should be in the rice. Now leave this overnight atleast. If possible, leave it for 2 days.
Then, assemble your phone again. It should work fine now. Atleast mine did. :)
Hope it works for you too.
Plus, as you have already done the first part and dried it, just leave it open under a fan etc overnight and it will work fine.
Apr 03, 2009 | Nokia N73 Cellular Phone
My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Feb 03, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
448 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
