Question about Nikon Coolpix SQ Digital Camera
System error when i switch on the camera it shows system error but i can still see the pictures in the memory card. i reset already and format the memory card as well but still it appears system error when i opened. please help.
  • 2 more comments
  • perdika Nov 06, 2007
    system error
  • Anonymous Dec 04, 2008
    same problem, camera fine when turned on in set up mode, and going from set up to view pics on card, but when i try to go into any mode that uses the lens, i get a system error message
  • desere Feb 18, 2009
    I get a system error message everytime I turn it on Can anyone sugguest anything other than beating my camera?
  • Alice Redka
    Alice Redka Dec 07, 2017
    Beating works.
    Problem Solver:
  • 5 Answers
Turn on and off 6 or 7 times while banging on the body beside the lens, worked for me, apparently coolpix lenses tend to stick, as my girlfriend says " a good bang will solve many problems"
Posted on Dec 04, 2008
Thanks. recharged battery fully and gave it a few good clouts.
with may hand whilst turning on a few times WORKS!!!!
Posted on Feb 26, 2009
Canon elph 300hs error code e02
Canon has reserved the 02 error for memory card error. But your camera should tell the errors in plain text. If you did not switch the memory card to the Lock, there is a possibility the file system is corrupted.
Try to save all pictures you still can find on the card. Use an external card reader.
If no important pictures are on the card, you could give it a format. Please always format a new card in the camera, before you start shooting. Even when formatted in an other camera from the same brand, could cause problems. If after a format, the error is still coming back, try an other memory card.
May 04, 2014 | Cameras
Memory card full
If you already used the card in the same camera, the only thing I can think of is you did switch the lock switch on the SD memory card. Or there must be one or more protected images on your card. If the card comes out of another camera be sure it is a SD or a SDHC card, not bigger than 16 Gbyte because a SDXC card would be one size to big. The manual says max card size 16 GB
If you accedentely formatted the card in the PC (or MAC) it could be you did put a format on the card the camera does not understand. Most camera's use FAT (max 32) and never NTFS.
Try to format the SD card in your PC.
Nov 04, 2013 | GE X500 Digital Camera
FORMAT ERROR shows up in the window. Cannot take pictures, or review shots. Gateway DC-T50 Digital Camera The problem occurred after I tried to hook it up to my Mac computer to download pictures which I...
Remove the batteries wait a few minutes. Put fresh batteries back in and turn the camera on. This resets the camera.Then remove the memory card from the slot from your camera. Then insert back and check you will not be getting this error.
If still there is some problem, take the memory card out and copy the pictures from the memory card to system and then format it. Insert the card back to the camera. You won't get the format error.
Hope this helps.
If you still have any queries feel free to ask us.
Feb 18, 2011 | Gateway DC-T50 Digital Camera
When you get memory card error on every card you put in your camera, what needs fixing? The camera or the card? All 4 cards gave the same error. I already got all the pictures off of them and deleted...
You said it in the last seven words "deleted the pictures off the memory cards" Once the pictures have been downloaded to the computer Hard Drive you need to Format the memory card. Formatting a memory card is done in the camera it is to be used which brings it back to a clean surface and compatibility. Your manual said that "normally" formatting isn't necessary which is a pile the bull left behind. I could go into detail as to why format but I'm trying to keep this short/
Here is a diagram to show you where the "format" menus is and what to do with it.
Jan 18, 2011 | Panasonic Lumix DMC-FZ20 Digital Camera
Have canon rebel xs , getting card write protected error
If this is a Canon Rebel XS there is no memory card in a 35mm film camera If this is a Rebel XSi then generally this error is caused by the memory card lock switch here is a diagram to show the correct orientation of this switch
Also after you have unlocked the card you should format the memory card in the camera it is going to be used in. Failing to do so may produce other errors and possibly corrupt pictures and files Formatting clean the memory card to produce optimum performance between the camera and card
Jan 18, 2011 | Canon EOS Rebel XS 35mm SLR Camera
Where is that switch to reset on the memory card protection? Whgen I try to take new picture the screen shows as follows:reset switch on memory card, where is that switch?
On the card itself (the tiny slide switch on its side). There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 05, 2010 | Kodak EasyShare V1073 Digital Camera
Card error
If you get a message as "Memory Card Error" on your camera AND you still need some of the photos , the first step is to format the card through the camera menu (Note: if you have an sD card, once you re-format your card any photos cannot be recovered.). check your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
To format* a memory card:
(*instructions on formatting memory cards can be found in your camera's user manual) you equally format the card using your computer if the above method fails,if the micro sd card is inserted into the sd slot of your system the computer sees it as a storage device in that way you can format it the usual way you can format a drive on your system but mind you if you have valuable pictures on it ,they will be lost but in that case you can use the low level format utility
Jan 06, 2010 | Olympus SP-700 Digital Camera
Olympus Stylus, keep getting error message to format card. Formatted card and had to erase pictures in the process. Took more pictures and got error message again. Plugged camera into PC and there are no...
Seems like your Memory Card already damaged and corrupted.If you still want to use it, try formatting it using your Computer, again and again.
If the problem still persist, there's no other way, you have to buy the new ones.
Dec 08, 2009 | Video Cameras
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Clean or format card error on Olympus XD card
my camara showing error message that clean card or format card,
i have some important photo in memory card so i can,t format the memory card.
while i am connecting with USB cable it,s showing syntex error
help me to retive the thw data..
Jun 05, 2008 | Olympus Camedia C-350 Digital Camera
Nikon Coolpix SQ Digital Camera Logo
316 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
