Question about Audiovox VM9512 Car DVD Player
Jensen VM9512 NO AUDIO! Fried?
I have a VM9512 with no audio - no sound in any of the speakers when set to any source. I know it's not a wiring issue because I have another head unit that functions correctly.
I measured the voltages in all 8 of the speaker wires coming from the head unit. 6 of the wires measured 4.5V. The white wires however clearly aren't outputting the correct voltages. The white/bk (-) wire measured 11V, the white, (+) 0V. When connected to the speaker the white wire measures 0.14V.
I guess my big question is, is there any possibility that this issue is being caused by a user replaceable component, rather than an IC chip?
I would appreciate any suggestions.
SOURCE: jensen VM9512 in-dash DVD player
with the remote:
press set up button
scroll to highlight language
enter 5,4,3,2,1,0
you will now be in a secret menu
turn on brake bypass
and exit
Posted on Dec 31, 2007
i dont have solution, but i used this one and it seriously worked.
Posted on Jan 04, 2008
SOURCE: jensen vm9512 unlock code for the code
oops forgot the 0. thats 543210
Posted on Jul 01, 2008
SOURCE: jensen vm9512 -- is there a master unlock code
ok i got a hold of audiovox call center and to bypass or unlock your stereo
you have to type on the radios password (very begging) blue screen
5,4,3,2,1,0 this is the factory reset for all the jesen i hope
it worked for my VM9512 !!!!!! with the lost user password
hope this helps
Posted on Sep 30, 2008
  • 165 Answers
SOURCE: problem to see the information in the screen jensen vm9512
call 919 562 5445 jensen parts
Posted on Mar 20, 2009
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
Wiring diagram for vm9512
type the name of your device preceeded by wiring instructions/diagram in any search engine. that should do the trick
Jul 19, 2010 | Jensen Car Audio & Video
It don't play audio through cd or dvd
are you running audio through an amp? if you are, you are probably using the power antenna remote wire instead of the amp remote wire.
Nov 16, 2009 | Audiovox VM9512 Car DVD Player
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
Jensen VM9512HD wants a passcode.
Jensen VM9512 Factory code is: 012345.
May 17, 2009 | Jensen Car Audio & Video
Rear zone sound not working
Do you have the manual? Here is the link
And is no IR transmitters in the unit. Let nme know if you still have audio issues aftr reading the manual.
Larry T
Winona Lake, IN
Jan 23, 2009 | Audiovox VM9512 Car DVD Player
I have a jensen vm9512 that I can't get the rear zone sound to work
i installed a rear monitor where my rear entertainment was and i just unplugged the unit. this caused no sound in the rear speakers. all i did was hook up the rear entertainment and put it somewhere out of the way. this is a possible solution.
do a search online. It's very easy. You don't need to worry about connecting up the brake wire.
Jan 23, 2008 | Audio Players & Recorders
Audiovox VM9512 Car DVD Player Logo
109 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
