Question about Clarion DUZ385SAT Car CD/ MP3 Player
My brightneess is too low, can I adjust it?
Everything works, but my brightness makes it too hard to read the display
IT-800-EC-35. How do I brighten the screen?
Adjusting Display Brightness You can use the following procedures to adjust display brightness to make it easier to
read under different lighting conditions.
Press the "Fn" key and then press the "5" key or "6" key after con? rming that "F"
is displayed in the lower right corner of the screen. Pressing the "5" key adjusts
brightness for a darker display, while pressing the "6" key adjusts brightness for a
lighter display.
In order to continue to make adjustments, press the "5" key or "6" key again after
? rst pressing the "Fn" key.
Brightness settings can also be made by navigating to the menus and tab in order of
Start ? Settings ? System ? Backlight.
The manual is here:
Casio IT 800 Series User Manual
Aug 04, 2015 | Casio Computers & Internet
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
Want to adjust brightness and contrast on monitor
First you need to know the Make and Model of the Monitor. Second, go back to store where you bought the Monitor and aske for a Manual. Third, when you learn about the Make and Model of the Monitor, search Google for an Instruction Manual to it. Any of these suggestions would help you!
Oct 23, 2017 | ACER INCORPORATED eMachines eMachine...
Lcd display is what seem to be to bright hard to read black info .or the black symbols are very light hard to read with bright orange lighted display thanks Mark
You don't say what device this is on, HOWEVER most thngs have a "contrast" control that will adjust the visibility.
Sometimes they call this a viewing angle control and sometimes it is a small shaft from the back of a unit, OTHER times it is a setting available through a menu... if you can read the display enough to find it...
Oct 12, 2010 | Music
Too much brightness
Set the ISO to a lower number and make sure your "exposure compensation" is at "0" or lower if you prefer.
Jul 04, 2010 | Olympus Stylus 710 Digital Camera
Screen is dark
adjust it with, with the buttons, to increase the contrast,
either go to display settings in control panel,, and adjust your screen resolution and, brightneess
May 16, 2010 | Dell Latitude D600 Notebook
Im a graphic designer and my hp1502 screen is just to bright making me get all my colours wrong ,ive tried adjusting the controls but to nothing works ,is there something in circuit i can adjust to get my...
The best way is through the buttons in front pannel. It will bring an OSD (On screen Display). Adjust the brightness and contrast from there. ( But I guess you have tried it allready )
Then the other solution which i uses to brighten my display is Power Strip.
You can also lessen the brightness/sharpness/contrast.
Chech this link to read about it and a free trial download . Click here.
If helpful, kindly Rate.
Jul 18, 2009 | HP L1702 17" LCD Monitor
Blue green screen on my desktop. Autofocus on my desktop doesn't work.
Where did you try to adjust the color?  In display properties, or on the monitor controls?  Make sure both have green at a normal level.  Then, make sure your cabling is OK.  Then, try a different video source for the monitor and see if that fixes it; if it doesn't, you get to repair the monitor.  If it does, you can just reinstall the video drivers on the PC.
Apr 18, 2009 | Computers & Internet
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Clarion DUZ385SAT Car CD/ MP3 Player Logo
54 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
