Question about Kenmore Ovens
Oven door will not unlock
The oven door on my Kenmore electric range (model #911-4658811) locked following a brief power outage and will not open. I have tried touching and holding the cancel button, cutting power to the range, and waiting several hours. Nothing so far has worked. There are casseroles in there I need to get out. Is there anything short of breaking it that will open the door? Help!
  • 4 Answers
SOURCE: unlocking oven door??
Try pressing STOP/CLEAR, then pressing in and holding the door switch plunger for 6 seconds on the upper right hand corner of the door.
Posted on Sep 17, 2008
SOURCE: Kenmore 790 Oven Locking mechanism problem
Well... I found the reason why this happened. We had a mouse and now don't have a mouse. I took off the back panels of the oven after unplugging it and located the motor that controls the lock. Well, a mouse decided to rest there and was electrocuted causing a short of the motor. Since the motor is out of commission I discovered that I could move the circular pull into a position that moves the locking latch to open allowing the oven to be back in working order.
Posted on Sep 26, 2008
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
Posted on Nov 18, 2008
SOURCE: Oven Door Lock
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
Posted on Apr 01, 2009
SOURCE: Electric Kenmore Ultra Bake Oven
i have a kenmore ultra temp electric stove and the oven will not heat up. I had it set for 350 and it only climbed up to 177
Posted on Apr 02, 2009
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Cleaning Kenmore double ovens back to back. During second cleaning got F9 code and the bottom oven is locked. Cleared the F9 will the bottom oven unlock when it cools down?
Jan 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a frigidaire mef352bgwd electric oven- after a power outage the lock engaged (door open) and now blinks continually. Tried shutting off breaker for 30 minutes- no change.
There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
Jan 07, 2010 | Frigidaire GLEB27S7A Electric Single Oven
Upon recovery from a power outage, the oven door on a Kenmore model #911455881C engaged the automatic door lock, and it will not release. I have cycled the power off and back on; have tried starting the...
I traced the problem to a faulty motor in the automatic door latch. In an effort to get the range operable again quickly, I removed the latch and got the door open. However since I just removed the latch and did not rotate the cam on the motor, the electronics did not "know" that the door latch was open, and therefore it still would not allow the oven to bake or broil. To remedy this I had to completely disassemble the motor and rotate the cam 180 degrees so the the sensors would recognize an open latch.
Dec 23, 2009 | Ovens
Older Kenmore oven- door locked by itself
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Nov 21, 2008 | Ovens
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 | Ovens
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
87 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
