Question about Panasonic PT-AE700U In Stock Multimedia Projector
Dust Inside lens
I see dust inside the lens of the projector. This seems to cause a blueish tinge on the hole screen which is more concentrated in some areas. This is inside the lens so not cleanable other than taking the lens assembly apart - is that even possible? Is this problem reparable?
SOURCE: blue spots on screen
Obviously this is not the first lamp you have replaced in you projector. These are great projectors however, the LCD panels expire quite quickly. You will find that the spots are related to the LCD panels needing to be replaced. This is not an inexpensive maintainence solution as the panels cost about $1500 each.
Posted on Jan 25, 2008
  • 26 Answers
SOURCE: Infocus x1a projector shuts down after 30 seconds - dust problem ??
Most likely, if it is a thermal problem, your main cooling fan has quit or is stopping after a short period. The problem is, I've seen several of these do this, and in every case, it is not the fan that has failed, but the Controller Board. And that is a very expensive part.
Posted on Mar 12, 2008
SOURCE: Image blurry at edges
my dear friend, it appears that you must have opened the 3 lcd screws that are not supposed to be touched, if so then just forget reassembling the same as the convergence would be lost & cannot be manually done
another thing are the polarisers.if excessive dust had accumulated & if you used wrong technique in cleaning then the coating would have come off & you have lost everything , just change the entire lcd block.this costs a bomb.beter to buy a new projector
Posted on Feb 08, 2009
projdoc
  • 2237 Answers
SOURCE: i need to remove 2 blob dust in projector ptae2000
canned air. remove the top of the projector and blow out the dust from every nook and cranny.
Posted on Aug 19, 2009
Wolfman304
  • 720 Answers
SOURCE: acer projector not clear on screen having many
Firstly, try the focus function on the lens...
If spots are still present, then there is either:
a) foreign particles inside the lens
b) the LCD panel/s (guessing it's LCD, as you did not specify) have dead pixels
c) the colour filters are damaged
Cheers,
"If this has helped you in any way, please rate this solution" :-)
Posted on Jan 27, 2010
How do i clean the inside of the lens? there is dust on the inside and it is causing alot a little white spots to appear on the screen.
take a little paper towel make it thin and stick it in their and wiggle it arround and wiggle it around like you just dont care,. ; )
Dec 28, 2010 | Optoma PRO250X Projector
There is dust inside the lens. how do I clean the dust from inside the lens?
Your projector needs little maintenance. The only thing you need to do on a regular basis is
to keep the lens clean.
Never remove any parts of the projector except the lamp. Contact your dealer if other parts
need replacing.
Cleaning the lens
Clean the lens whenever you notice dirt or dust on the surface.
• Use a canister of compressed air to remove dust.
• If there is dirt or smears, use lens-cleaning paper or moisten a soft cloth with lens cleaner
and gently wipe the lens surface.
Never rub the lens with abrasive materials.
Nov 27, 2010 | BenQ MP623 DLP Projector
Im using sanyo pdg-dsu21b model. right now, my projector has this little white bright spot all over the projection. can anyone please tell me whats the problem with my projector and what is the solution...
Unplug you projector and allow the bulb to cool. Open the area where the projector bulb is located. Check the projector lens for any damage and clean it from dirt's and dust. Same as with the bulb.
Nov 09, 2010 | Sanyo PDGDSU21E DLP Projector
Hi there my benq dlp projector is showing white spots on the screen when the screen is black can you help me?
This is caused by dust on the lens assembly. If you can remove the lens, clean the surfaces with a lens cloth. That should resolve the problem. It is possible that the there is dust in the optical pathway inside the unit as well. If the cleaning of the lens does not resolve the problem, the unit should be brought in for a professional cleaning. It is not suggested that anyone open up these units as there are fine adjustments that can be changed internally easily that could result in convergence problems.
Dan
Jan 29, 2010 | BenQ PB6100 Multimedia Projector
I have what looks like particals of dust on the screen that is worst at certain focal points can i cure this ! thanks
blow the dust out with canned air. if you can focus on the dust, chances are it's on the first lens inside the projector.
Nov 29, 2009 | Hitachi PJ-TX10 Multimedia Projector
The left side of the screen is blueish?
The blue or yellow haze problem in this projector is because of two factors. 1) Dust buildup inside the optics and 2) Fading colour filters used in the internal optical process.
Inside the projector the white light from the lamp is split into three distinct colours of red, green and blue. Each colour illuminates their own monochrome LCD. Those LCDs are mounted on a prism that combines the separate images and displays the result you see via the lens.
The optical process to split the light up inside the projector is fairly complex and involves many light filters and mirrors to direct the light to the appropriate lcds. Those filters and lenses accumulate dust and also fade over time due to heat and other environmental factors.
I know that sharp sells replacement filters at $100 a piece. I do not know if Hitachi sells replacements.
To remove the dust and change filters you have to take apart the projector in a fairly complex way. I do not suggest that the average user do this. Good luck!
Mar 18, 2009 | Hitachi CP-X445 LCD Projector
My projector Benq pb6200 needs cleaning from the inside how???
I have an Optoma EzPro 737 DLP projector that accumulated dust inside the lens and for ages I couldn't figure out how to get rid of it. It cast shadows onto the picture and scattered light outside the edges of the picture. I thought I'd have to dismantle the whole lens assembly (then realised that this is virtually impossible without being an expert). I then stumbled upon a little black rubbery plastic panel on the side of the light path, which unclips. I then realised that the dust had built up on the lens that sits in front of the DMD chip (the thing that makes the picture).
Here's what I did, with the case open and having vaccuumed out all the dusty parts of the projector to avoid making the situation worse:
- Took off the little rubbery panel,
- Removed the lamp from the projector and placed a flashlight inside, shining into the light path (or a mirror directing light from a table lamp above)
- Looking directly into the lens from close up, you should be able to see the particles of dust stuck to the inner lens (with a nice magnified view)
- First tried blowing air into the gap on the side of the light path (I used a balloon pump).
- Next, I poked a piece of thick nylon fishing line into the hole so that it could touch the surface of the inner lens.
- While looking into the lens, I could see the tip of the nylon, then directed it to the largest dust particles and used it to scrape them off (nylon is much softer than glass, so won't scratch the lens).
- This was quite time consuming but I got rid of the most obvious bits.
I'm not sure how different this would be for another model of projector - but I hope it helps!
Dec 16, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
Vpl cs5 dusty lens from the inside
not too difficult to do.
requires cover off and minor strip down.
if unsure consult a tech.
Dec 06, 2007 | Sony VPL CS5 Multimedia Projector
55 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
