Question about Garmin Nuvi 660 GPS Receiver
Microphone not picking up any sound in bluetooth mode.
Regarding my Nuvi 660 in the blue-tooth mode the unit does not pick-up any sound. I can hear all the sound on the other end of the phone call but by all appearances the unit's microphone is not working. The unit is out of warranty and working fine with the exception of this one problem.
  • Garmin Master
  • 2,130 Answers
Hi Joe,
First, I would go to the Garmin website and update the bluetooth software. Garmin just released v3.4 a few days ago (November of 2008). Use their webupdater to upgrade the BT firmware.
When you update the firmware, it will erase your phone paring data and you will have to re-pair the phone with your Nuvi.
Now, if that doesn't fix your microphone issue, you have either one of the following two problems:
1. The microphone is a condenser microphone. It's about a 1/4" in diameter and sits behind the front slot located in the lower left hand corner. The microphone has two wires (red & black) that run from the microphone to the main board. At the end of the wires is a 2 position plug that plugs into the main board. This plug can come loose as there is no lock mechanism on it.
2. The microphone is defective.
Please do not try to take apart your Nuvi unless you have the right tools. I have received many emails from people who have further damaged their Nuvi, trying to get it open.
Please let me know if you need further help with this problem.
Good Luck,
- Jim
Posted on Nov 18, 2008
How can I fix my blue-tooth so the other person calling can hear me?
Sounds like a setting issue, i.e. you have your blue-tooth on mute. Check the instruction manual and turn mute off!
Oct 17, 2015 | Plantronics Black Marque M155 Wireless...
How do i turn on my bluetooth on the Garmin nuvi 205
The blue tooth is always on. Just set your phone on pair and it will find the gps if the gps has bluetooth.
According to this SPEC PAGE - your unit does not have blue tooth.
May 06, 2010 | Garmin nuvi 205W GPS Receiver
On my ps3 bluetooth scanning for a ps3 headset its
Make sure that your blue tooth is in pairing mode when the sysytem is scanning.(refer to blue tooth headset manual for intrustions)
I hope i have helped and I hope it works!!
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
How do you install bluetooth in garmin nuvi 260w
I'm not 100% certain, but I don't think it has a blue tooth transceiver built in. But, correct me if I'm wrong...please, I have one also and would love to have blue tooth.
Jun 25, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Garmin c550 phone book problem
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
just model number is different but the system is same
hope this helps
Nov 25, 2008 | Garmin Nuvi 660 GPS Receiver
Blue tooth
Download and run the Garmin WebUpdater. There is a new version of the firmware availabe for the bluetooth.
Sep 09, 2008 | Garmin Nuvi 660 GPS Receiver
Won't pick up satellites
It fixed my garmin Nuvi 660:
With the unit off press firmly on the upper left hand corner of the screen with the tip of your finger.
2. Press the power button. When you see the screen light up let go of the power button but continue to press on the upper left hand corner of the screen until you receive the message "Do You Really Want to Start Up In Maintenance Mode?"
3. Say Yes and then select the third Option "Clear All User Data" and then say Yes.
4. The unit will then start up and ask you to set some preferences.
5. Once the unit is on the Main Menu please sit it in a safe place outside with a clear view of the sky for about 10 minutes and let it lock on to the satellites.
Jul 09, 2008 | Garmin Nuvi 660 GPS Receiver
Blue tooth phonebook
The unit does not save the phone book, it loads it each time your bluetooth phone is in contact with it. To verify this, turn off the bluetooth phone, then try to access the phone book in the GPS unit. It should not come up.
Mar 26, 2008 | Garmin Nuvi 660 GPS Receiver
Need Info
Read the manual and you will be able to connect Bluetooth TO 660 , menu Bluetooth active , be sure you LG phone is active on his bluetooth, connect and recognize will be done , you will see.
GARMIN 660 is working with a battery and also with your car adapter. I don't see any reason why it would not work on battery ?.
Your issue is not clear concerning the battery ?
best regards
Dec 31, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin NUVI 660 BlueTooth
I had the same problem, and this is how I fixed it. Now it's working fine.
Thank you for contacting Garmin International,
If you are currently running the most current version of bluetooth software, and you are still seeing issues where your compatible phone is still not connecting properly, please try the below procedure, which will reinstall the version of bluetooth you have downloaded in case there was any corruption during the transfer or installation of the bluetooth version.
1. Power the unit on
2. Touch View Map
3. Touch the ETA/Speed button in the bottom left hand corner.
4. press and hold your finger over the speedometer for 10-15 seconds until a new screen appears.
5. Touch next at the bottom of the screen until the top blue banner reads Bluetooth Status.
6. Touch UPDT P, then Touch yes.
7. At this point the unit should go to a page that says Updating Bluetooth Firmware, allow this to finish, once finished, press quit, then press and hold the back button. At this point, go back through and try to connect your Bluetooth device again.
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
187 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
