Question about Vector VEC 024 400-Watt Power Inverter (VEC 024) 400-Watt Power Supply
I need to find replacement ground (thumb screw) for vector 024
The model is vec-024 and has a blue outer metal cover "force 350" serial number 088665
  • aberyjr Nov 18, 2008
    i tried but the screw pattern is not the same as most nuts..a 8mm nut will fit on the screw but will only turn once witch leaves about 5/16 of the terminal exposed a 5/16 nut will also fit but will only turn once. "the turn per inch" doesent match
  • 959 Answers
Ground it off on the case...any grounding method should work. Unless you are talking about the main connection terminals... then just replace the missing thumb screw with a short screw and an eyelette type connecter.
Posted on Nov 18, 2008
  • ZappaNut
    ZappaNut Nov 18, 2008
    I've got a 350 watt inverter in the barn... (and a 1000 and 2000 as well as I use em in my van customizations) I'll see what will fit it and get back with ya.
    Are you in the U.S. ? I can just mail ya one off of mine maybe , should I not beable to determine what the nut size is. The 350 is on my 'jump pack' for use as portable A/C when needed , and is connected via the lighter plug so I don't use the thumb screws anyways.
I need the bulb assembly for a Vector VEC 137-C-WM 1,000,000 CP rechargable spotlight
Vector is a part of the Black and Decker company and almost all items with that name are made in China.
I assume you tried to Google the model number for "bulb" or "lamp"
Dec 15, 2012 | Vector 1 Million Rechargeable Spotlight
I can't find the user manual for Vector flashlight/spotlight model # VEC 1138.....where can I get this? Thank you
Here is the manual.
Please give four thumbs up for my response if it helped!!
http://www.baccusglobal.com/bd/manuals/NEW%20MANUALS%20FOR%20WEB/VEC1138%20MANUAL.pdf
Aug 25, 2011 | Vector 1 Million Rechargeable Spotlight
I need to replace the fan. Where do I find one.
you may find that walmart has those for under 20.00 and a fan is 25.00 and you take a huge risk of electric shock and damage to your car or equipment trying to do a stupid pos inverter, get my drift?
walmart.com
Dec 02, 2010 | Vector VEC 024 400-Watt Power Inverter...
My Vector Flash light is not working, I have tried to fix localy in Santa Barbara, but was unable, there is a place to send them to be fixed, my model is Sport Spot 3 million, thanks
Baccus just bought Vector from Black & Decker (Sept. 2010)
Looks like flashlight model # VEC 139BW but a different color. (Mine is White w/blue trim.) There is a battery in the top & one in the bottom, replace them at the same time. If I can find several battery stores in Buffalo you should be able to find a local battery store there.
Baccus- 877-571-2391 for main beam, area light no longer available. Try to find local distributor & save shipping charges.
Sep 23, 2010 | Vector 3 Million Candlepower Rechargeable...
A ups mosfet ckt one mosfet burnt out og 16 can i replace only one
Usually the mating one has been degraded or damaged as well. Replace as a pair, or all of them that are in the same function.
OFTEN driver transistors and drive diodes are also damaged. Carefully check all associated components to avoid burning out freshly replaced ones.
Mar 14, 2010 | Vector VEC 024 400-Watt Power Inverter...
I have a vector vec 156 that i can not get the
The rubber cover will have to coxed off. There is a slight lip that it sits in at the back. I ran a screw driver under it around the back of it to get it dislodged and then worked it forward.
Feb 02, 2010 | Vector Camping, Backpacking & Hiking
When I charge my jump starter, do I have it on or off for it to charge?
off, never leave it on, danger of short if the clamps touch metal, turn it on only when you are using it to help start a car
Jan 09, 2010 | Vector VEC 024 400-Watt Power Inverter...
I think my inverter burned.
it depends on what burnt in it, you should check it out to know
Jan 13, 2009 | Vector VEC 024 400-Watt Power Inverter...
Does item have a fuse? Burned out
i have the same one ...and i'm not seeing a fuse, there may be one internally
does the inverter have strong "burnt wire" smell if so it is probably fried.
Aug 16, 2008 | Vector VEC 024 400-Watt Power Inverter...
Vector VEC 024 400-Watt Power Inverter (VEC 024) 400-Watt Power Supply Logo
218 people viewed this question
Top Vector Computers & Internet Experts
janman
Tom Chichester
Are you a Vector Computer and Internet Expert? Answer questions, earn points and help others
