Question about JVC Televison & Video
JVC Model HD-52Z575 Picture will not come on. Observations---The POWER LED and LAMP LED are blinking rapidly simultaneously. If I remove and install bulb it will come on and operate till shut off then will not come back on. Reg Gram
  • 1,269 Answers
Did you visually check the circuit board for any possible burned components? Usually its a capacitor and resistor. Please check the power supply board as well for any burned components like fuse. Also double check any shorted and cold solders.
Posted on Nov 18, 2008
I just replace the bulb in my JVC HD-52Z575 everything was fine for about 10 days. Now when I turn the TV on it works for about 30 to 45 min before it shuts off, the fan kicks in, and the LED power light...
Ballast Board? it is what Powers Lamp, or CK Lamp Fan if it stops running and is not Keeping Lamp Cool
set is designed to shut off to Protect lamp from being burted up, you could have either Bad Ballast Board or Defective Lamp Fan,there is a few test you can do to see which Part is Bad.
Jan 25, 2010 | JVC HD-52Z575 52" Rear Projection...
Rapid blinking light (lamp) on a JVC model HD
It normally means the lamp is in need of being replaced, and its all depending on the use of the TV as well as how long the lamp life is. You should be able to access the lamp via a small section near the rear or the back of the TV unit, if the lamp is blown or faulty it will look the same as a blown light globe.
To obtain a new lamp contact the brands authorised repair agent as they will be able to get trade prices and in turn, give you the best price,
Also make sure that whoever replaces the lamp resets the lamp use time as the TV will still not start if you don't reset the lamp use time as it will still think it has a faulty lamp. I hope this helps, good luck.
Dec 05, 2009 | JVC HD-52Z575 52" Rear Projection...
The power led and lamp program led are binlking rapidly simultaneously
Your lamp is burned out, order a new one for your tv model and follow the instuctions that the bulb has and you can do it yourself, dont get conned into thinking it is more technical than it is by the repairmen on this site
Dec 03, 2009 | JVC HD-70FH96 70" Rear Projection HDTV
I have that same problem...we replaced the lamp and nothing happens we hear the fan go on but it goes of .
Jul 04, 2008 | JVC HD-52Z575 52" Rear Projection...
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC HD-ILA Projection TV
From the manual...
and LAMP LED are
• It may be a malfunction that the fan is locked or the temperature has increased.
and LAMP LED are
blinking rapidly
• The lamp may not have been installed correctly, or it may be due to a malfunction.
• The lamp door may not be closed correctly.
continues blinking
• It may be a malfunction of the internal electrical circuits
Feb 16, 2008 | Televison & Video
The power LED and LMAP LED are blinking rapidly simultaneously
Will you will have to replace it now because this is the most likely cause for the blinking lights. Look in the instruction book for the directions on how to remove the lamp. You will find that it has burned out. It is easy to replace. You can order one from JVC or a service center, or a parts distributor.
Dec 03, 2007 | JVC HD-52Z575 52" Rear Projection...
Televison & Video Logo
105 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
