Question about Maytag Refrigerators
Maytag refrigerator cooling probelm
My Maytag refrigerator Model No. RTT1900DAE has cooling problem. The freezer is kind of working, but no cold air come down to the fridge. The "ceiling" of the fridge has ice. The fridge is warm.
  • cjerid Nov 23, 2008
    Thanks for drkoole. I have inspected my rridge, it was the defrost heater broken.
  • Anonymous Mar 16, 2014
    Our Maytag refrigerator is running warm. The freezer is fine. Seems that no cold air is coming through the vent from the freezer.
I got the suggestion and will try it this weekend. Thank you!
Posted on Nov 21, 2008
    Problem Solver:
  • 19 Answers
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
My Maytag Plus side-by-side refrigerator model # MZD2766GES is not keeping anything cold. The freezer side seems to be working just fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag top-freezer refrigerator model RTT1900DAE. The fridge works great. I've placed a memory thermometer in there and the low/high temps are normal. The freezer on the other hand doesn't stay...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 15, 2011 | Refrigerators
I have a Maytag fridge MTF2193arw, the freezer is nice and cold with the fan working, but the fridge is not cold with no air movement.The unit is 3yr
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 15, 2010 | Maytag Refrigerators
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Samsung refrigerator RS264absh Freezer not cooling
I would check three things in your freezer seeing how your getting ice the t-stat ,the heater,and the fan these are the first things you check with ice build in freezer your freezer is what actually produces the cold the air from the freezer travels through small vents into your refrigerator sounds like a definite defrost probelm in your freezer
Apr 28, 2010 | Refrigerators
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Maytag model # mbf2254hew bottom freezer refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 22, 2008 | Maytag MBF2254H Bottom Freezer...
Refrigerators Logo
396 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
