Question about Bausch and Lomb Bausch & Lomb Hunting Elite 4200 Riflescopes Matte Finish With Sunshade Pow
RIFLE SCOPE STUCK ON 8x POWER
I am unable to dial my Balfor 8B rifle scope down from 8X power. No amount of force could move it.
  • Anonymous Mar 21, 2014
    How to set a rifle scope
    Problem Solver:
  • 8 Answers
If the scope's minimum power isn't 8x then it's broken. Call the customer service rep of the company and see how you can return it. Depending on the warranty they may fix it or replace it. I'm not familiar with Balfor as I don't shoot BB guns. You can move the ring around a bit, see if something loosens up, but don't force it.
Posted on Nov 26, 2008
How to sight in crosman extreme g1 pellet rifle scope
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
May 05, 2011 | Sport & Outdoor - Others
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
1. HOW TO READ SCALING OF SCOPE.? 2. What is
You have not provided enough information for us to help you. What type of rifle? What do you mean by scaling?
With the scope on 3 power you should be able to sight it in at 25 meters. Going to a higher magnification may cause blurring at that distance.
You also may have mounting problems that are causing the scope to move around when you shoot. Your rifle may be fine.
Oct 09, 2010 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Took my Pentax 4-12X 40mm rifle scope mounted on a Remmington 7mm mag bolt action rifle to hunt antelope in Namibia, SW Africa. First shot on a fine kudo blew up his heart and broke off-side leg bone....
you got it in one there,,,its all down to "head butting the scope"!
your head **** has pushed the eye bell up the scope body and has pinched or locked the power adjuster ring to the scope body
you have only two choices send the scope off for repair,,or buy a new scope,,,done even think about trying to fix it as you cant,,
it will need a strip down and then a re-gas (to stop it foging up)
so if you took it to bits the scope would be distroyed
Aug 22, 2010 | Pentax Optics
Tlescopic sight
I couldn't find the eurohunter model, but I checked out the website. Without a bore sighter, You can still get your scope to hit a paper plate at 100 yards by using a cardboard box. Then it will fine tune in just a few rounds. Only a bolt action though, you have to be able to see down the bore. Take a big box, or a rifle vise, cut some V's into the top edges, lay the rifle in there, pull out the bolt, find a target 100 yards away, put the bore of the rifle on it and don't move the rifle. Then put the crosshairs of the scope on the same target, check to make sure the rifle didn't move, then check the cross hairs again. You will be able to hit your target at 100 yrds, the ar 15 is an exception to the bolt action, you can see down the bore.
Feb 11, 2010 | Nikko STIRLING EUROHUNTER RIFLE SCOPE --...
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
Cross hairs canting to the left..how do i recenter the recticle?
From your short description, it sounds like the Horozontal (the ELEVATION) reticle is canted to the left. If that IS the case then do this;
Sand bag the rifle on what you know is a level and firm surface. The rifle MUST be level itself. You can use a small level to determine this.
Without moving the rifle, look through the scope and determine if indeed the horozontal or ELEVATION reticle is indeed canted. The reticle should be LEVEL in relation to the ground and the rifle itself.
If it still appears to be canted, loosen the set screws of the scope ring caps (Not the scope mounts) and while looking through the scope, gently rotate the barrel of the scope clock wise until the Horozontal reticle appears to be now level. Re-tighten the scope ring caps and look through the scope again to make sure the Reticle is still 'level'.
You must now make sure that your scope is still 'zero'd'.
IF the issue is something other than what I have assumed from your description, please send me a msg. with more detail and I will be able to resolve whatever issue you are having. Include the 'Brand and model', plus the power of it, and the brand/model/cal. of the rifle the scope is mounted on.
Good luck. :)
Apr 27, 2009 | Nikon Tactical Rifle Scope 4-16X 50...
I need a scope guide instruction sheet for the Tasco 28a
Dec 14, 2008 | Tasco Scope Guide Quickly Zeroing Rifle...
Bausch and Lomb Bausch & Lomb Hunting Elite 4200 Riflescopes Matte Finish With Sunshade Pow Logo
358 people viewed this question
Top Bausch and Lomb Optics Experts
Jeffrey
Jeffrey
james laughton
james laughton
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
