Question about QVS NetStar (UPS650A) UPS System
New battery will not recharge
I am having trouble with my NetStar UPS System despite having recently replaced the battery. The problem is that when it is not in use (turned off but plugged in wall outlet), it is unable to hold it's charge. However, if I leave it on, it is able to hold its charge and functions properly, e.g., during brownout, the computer will still function for a few minutes. The other problem is that once it is discharged, I am unable to properly charge it. The red light with the diagram X over a battery on the UPS panel remains constant on, while the green light also remains on. It usually takes about 2 or 3 days before it properly charges. And today has been the fifth day and the red light has not gone out. Appreciate any guidance.
    Problem Solver:
  • 7 Answers
Don't turn it off, the battery needs to be constantly charged or refreshed. They will go bad just sitting around with no voltage applied. The UPS draws very little power and has surge protection so there is very little to worry about.
Posted on Jan 25, 2007
How do i replace the battery on a netter xt 1200
Turn off power and unplug from the mains. Make sure the power button on the UPS is turned off. Remove the screws on the underside and remove the front cover. Pull the top part of the UPS upwards. Look for the battery connectors and remove the positive and negative cables from the battery. Install a new battery of the same value. Fix the positive cable first then the negative. Test it and close it up.
Jan 10, 2015 | QVS NetStar (UPS650A) UPS System
5kva ups dosn't switch on (ups is dead condition) main mode&bettery mode please any one ideas
Hi Santhosh,
Have you checked to see if the batteries in the UPS are any good? Most UPS systems refuse to turn on if dead batteries are attached.
Reply or call if you need more help with this -- 407.380.9200
Sep 28, 2013 | QVS NetStar (UPS650A) UPS System
I have Numeric 1000 Hp Digital Ups .now i have a problem With it .Always it is giving short beep sound, and displays shows "Warning 22".Battery back up is also not giving. During power failure instrument...
Replace the batteries in the UPS - that's your problem. Everything should work after that :-D
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Aug 24, 2013 | QVS NetStar (UPS650A) UPS System
My ups is suddenly getting off even continuous supply is given to it.I am using same ups for 3years can any 1 suggest what is the problem??
The problem will be in the battery in the unit. After 3 years the battery will be un chargeable the same as in the car. Batteries are available from most good battery shops . Take the unit in so that they can match it.
May 23, 2013 | QVS NetStar (UPS650A) UPS System
My PC is geting switch off when Power flatcutations come,even ups is connected and no back up comes from UPS, after that UPS takes >4 seconds to switch to mains supply.
A four second transfer time is way too long by at least an order of magnitude. There is no way the power supply in a PC can maintain for that long a time.
If you are in a real critical environment I would recommend going to a UPS which runs continuously and runs off a battery which is charged whenever utility power is available. That way there is no transfer time.
These offline units are harder to find however.
I suspect your UPS system is defective.
Apr 26, 2010 | QVS NetStar (UPS650A) UPS System
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
The ups is shutting down immediatly ,once the AC power is off
thats a dead UPS... battery is bad now... you probably need to have it changed...
Jul 09, 2009 | QVS NetStar (UPS650A) UPS System
Numeric ups with fault indication
Please Change Battery or Check the PCB Masfecter
Oct 14, 2008 | QVS NetStar (UPS650A) UPS System
How to charge UPS
iam having numeric digital 600-ex-c ups but it making sound when we on the ups .... how i can charge it?
Jun 05, 2008 | QVS NetStar (UPS650A) UPS System
QVS NetStar (UPS650A) UPS System Logo
360 people viewed this question
Top QVS Computers & Internet Experts
Bill Boyd
Norman Worley
Power & Systems...
Power & Systems...
Are you a QVS Computer and Internet Expert? Answer questions, earn points and help others
