Question about Philips Magnavox 20MS233S 20" TV
TV Comes On But No Picture
The power comes on, but when you put a channel on it has static and diagonal or horizontal lines going thru it or a Blue Screen. When you get the blue screen it you change channel on the remote you will get a picture with the lines again. Then if you click on a volumn button you can hear the sound. Started doing this a few days ago and got worse now it won't even get a picture UNLESS (this is the weird part) if you use the hair dryer or microwave the picture and sound will come on perfectly until you turn the appliance off then you get Blue screen again. Any suggestions??
  • 81 Answers
Check for bad solder connections on the pc board and a posible leaky cap
Posted on Dec 13, 2006
Hi i have the sony kv32fs120 the tv wont turn on the stand/by timer blinks but no picture tried to unplug for 5 min but it didn't work any advice. thakyou anthony
Possible failure in the horizontal section of the horizontal driver or the failure of the line output transformer.
You will have to disconnect the +B to confirm if the SMPS gives the power.If so check for short in this section .
respond.
Sep 30, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Sony Trinitron: Frozen Static Issue
you could be experiencing two problems. the first part of your description states the static with two horizontal bars, this problem is usually erratic and it is caused by a defective varactor tuner(this happens while watching a channel thru your channel selector) the second part that it also happens while using the front hookups could be taht the front input connectors have developed some loose solder connections and thus the video problems (very common problem)
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv does not have picture
Hi
this is horizontal power section issue... maybe you have leak flyback or leak capacitors...
Thanks!
Mar 11, 2009 | Televison & Video
Not getting full pic on certain channels
I've seen this problem before. Try to adjust the horizontal settings in the tv. you should be able to adjust the picture up just a bit and it will get rid of the lines. also if you are hooked up thru component or hdmi you should be able to press the # button on your time warner remote to fill the screen. Hope this helps.
Feb 10, 2009 | Philips Magnavox 42MF521D/37 Television
Blurry Sanyo TV
Well after playing around with the tv some more, I decided the problem was probably the cable jack, and tried running the video in/out cables thru the VCR to get around this, which I read generally works but in this case nothing. I had tried the tv on various settings, anytime I put the tv in "video" mode I'd get a blue screen and nothing else. Anyway I found a switch in the back of the Direct Tv box for ch. 3 & 4 settings. So I flipped it but still got a snowy picture, only this time it was on ch 4 instead of ch 3. By sheer accident I put the tv back in video mode while I had the satilites setting to ch 4, and the picture came up crystal clear. Since I didn't mess with it further, I'm not sure if it was the channel selector or the fact that hooked the tv up via the video cables, but whatever it was it did the trick.
I just KNEW this could not be a broken tv despite the fact that everhwere I read online suggested it was. I knew pictures can go out, or sound can go out....but to have BOTH go out didn't make sense to me. Anyway, glad its working! :)
Jun 15, 2008 | Televison & Video
Horizontal problems
Its may due to problem on IFsection or tuner,afc problem
Jan 12, 2008 | RCA D52W19 52" Rear Projection Television
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
White Noise Sound
Your problem is somewhere between the tuner and video detector circuit. The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess! After the audio passes through all this, it is detected and sent to the audio processor. If any frequency has drifted away from it's value then you loose the sound. SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem. Stargazer
Mar 11, 2007 | Proscan PS32600 32" TV
Philips Magnavox 20MS233S 20" TV Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
