Question about Sony KV-13VM30 13 in. Combo
Channels above 13 not availible and I don't have original remote.
I was given this t.v. and it shows the first 13 channels and the vcr plays. I was told that the t.v. needed to be "Programmed". I don't know what that means. I do have an "One for all" universical remote . I hope it will work.
0 characters
1 Points
Program channels without remote
Cannot be done but a replacement (original not universal) should be available from Sharp and not overly expensive.
Jun 13, 2012 | Sharp 13VT-R100 13 in. TV/VCR Combo
I have no remote for the tv Sylvania 6313ce 13" TV/VCR. I am trying to program a rca remote for it so I can change the channel to 3 so the converter box will work, how do I do that
This particular TV may have the same code as a Magnavox,Emerson, Funai ,or Zenith. You will have to look in the remote control manual for these codes. This TV was put together by other manufacturers. And in many cases they program these to their origin! Thanks for asking and show a few hands of support!
Jan 11, 2011 | Sylvania 6313CE 13 in. TV/VCR Combo
I was given a Magnovox tv w/o the remote and there seems to be a smartlock on it. It use to be that it would not let us watch R rated movies but now it's progress to PG 13. It also won't allow you to watch...
No,try website like to buy an exact to the original remote.Ask the person given u that tv.Give u that secret codes.Not resetable tv to erase any secret codes.
Jul 24, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
Trying to help this older lady with a emerson tv/vcr combo. She has no manual with set. Setting up to record same station everyday at same time. VCR will record but when playing back she only gets sound no...
The TV should be on channel 2, 3, or 4 to work correctly. There might be a small switch on the back of the VCR that lets you select the channel that it wil play back on.
Also, look on the remote control for the VCR and see if there is a button labeled TV/Video, and press that while something is playing. This switches back and forth between the TV signal and the VCR signal and it could solve your problem.
Jan 08, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
VCR plays tape with only sound and some channels seem deleted.
Needs the vcr heads cleaned, and get a universal remote with a menu button to change the tuner setup.
Jan 25, 2008 | Toshiba MV13P2 13 in. TV/VCR Combo
13" Sansui TV and VCR combo
ok! you can auto search the TV to find all Cable channels! but first you have to set mode TV /CABLE set to cable then you auto search!
Oct 12, 2007 | Sansui COM312AD 13" TV/VCR Combo
i have the same set i used a rca universal remote rcr311w i think its the oem one i bought two of them at walmart i don,t know if they still carry them
Sep 09, 2006 | RCA T13208 13 in. TV/VCR Combo
Screen imprint
No. sorry My friend, you have to use the original reomote. Theres a display button on this remote under the zero. Its available through as a replacement original. You can also see if anybody you kinow has a emerson TV with a remote,as most will work most sets. If thats not the case see if someone local to you sells emerson TVs or repairs them, and has one you can borrow for you to take off the display.
Sep 05, 2006 | Emerson EWC1304 13 in. TV/VCR Combo
Combination Televisions Logo
21 people viewed this question
Top Sony Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Sony Combination Television Expert? Answer questions, earn points and help others
