Question about Cyberhome Televison & Video
Cyberhome dvd player ch-dvd 300 What region code is this dvd player? can it play region 2 dvd's?
  • 80 Answers
Dear friend,
Try this method to change the region.
1. Switch player on, making sure that there's no disc in the tray.
2. Close tray.
3. Using the remote control, key in the following: MENU, 1, 9.
4. A menu will appear with the region option near the bottom of the screen.
5. Press ENTER, enter the desired region AND PRESS ENTER again to save the desired region.
6. Next press OPEN / CLOSE.
Posted on Nov 20, 2008
Need remote code
try this method THIS METHOD WORKS FOR THE CH-DVD 300, CH-DVD 300S, AND CH-DVD 320
2. Close tray.
5. Press ENTER, enter the desired region (0=REGION FREE )AND PRESS ENTER again to save the desired region.
6. Press OPEN/CLOSE. Hope this helps you with your problem
May 02, 2009 | Cyberhome CH-DVD 300 DVD Player
British dvd on toshiba dvd player,
Buy cheap dvd player that's hackable with remote to allow all region play.
Mar 25, 2009 | Cyberhome CH-DVD 300 DVD Player
Need a universal remote code for a cyberhome dvd 300
Cyberhome 300 DVD player codes... 20816 20874 21023 21129 21023 worked on my comcast remote for all the DVD PLAYER FUNCTIONS!!! =)
Jan 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Try to play DVD and when inserted it says WRONG REGION....how can I change the region w/o a remote?
Click this link for more info
if u tell brand name and model no. i will give the exact region code / better solution
thanks
Dec 28, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
Remote Codes
I found the code...
In the remote codes guide, the Cyberhome DVD player is listed under "Portable DVD"...the code is 2083...worked for me, enjoy.
Dec 28, 2007 | Cyberhome CH-DVD 300 DVD Player
Region Error
this is for: Cyberhome CH-DVD-300 1. Ensure the players disk tray is Closed with no disc . 2. Press Menu. 3. Press 1. 4. Press 9. 5. A menu will appear with the region number near the bottom of the screen. 6. Press Enter. 7. Select the desired region. 8. Press Enter to save the settings.
Jan 31, 2007 | Cyberhome CH-DVD 300 DVD Player
Multi region for CH DVD 300
There's a tricky process to follow with the remote control to set the region code. It is: -Open the player. -Remove any DVD. -Close the player. -Power off the player. -Wait for 30+ seconds -Power on the player. -Press Menu,1,9 on the remote [this frequently takes a few tries]. -When the region screen appears, press enter to change region (Every time you press enter, the region code on the screen will increment by 1). -When the proper region code is displayed, press Return. -Open the player. -Insert DVD. -Close the player. -(Maybe just my player) If the player doesn't start the DVD, repeat Open/Close until the DVD starts. If it still doesn't start, power off for 10 minutes. Good Luck!
Jan 21, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD Player stops in "Loading..." mode
1. Check that disc is encoded for your geographical region. A disc from Europe (Region 2) will not play in a North American (Region 1) player. 2. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on. 3. If your player has a transportation lock (usually a plastic screw on the bottom of the unit), make sure that it is not engaged. 4. If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players. if nothing helps, call for service.
Sep 12, 2005 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
79 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
