Question about Acomdata HD250U2FE-72 (hd250u2fe72) 250 GB Hard Drive
Can i open the external and use it directly as a hard drive? it isn't working as an external.
My acomdata has been working for me for al ong time and its been through some very tough times. Fair amount of shock, and now its essentially stopped working. It will still turn on and the fan works, and even the computer knows when its on or off (the litle ding noise goes on/off when it is turned on/off) BUT the harddrive makes a funny noise when its on and nothing will show up on the computer. I need to get a new external anyway so what i'm wondering is if i can take it apart and plug the hard drive directly into my computer using ribbons. Does anyone know if i can do this? Because i'm sure the actual hard drive is fine. They are extremely tough. If you have any informtation about this please let me know. Thank you very much.
    Problem Solver:
  • 12 Answers
Most enclosures can be opened and the drive removed to be installed physically into your Pc. Make sure your jumpers are installed correctly for the position you intend to install it on the ide cable ( ribbon )either master, slave or cable select. Usually when you hear a noise coming from the HD itself , that's not a good sign. you might experience your pc not even booting with that HD installed if its really messed up. Good Luck.
Posted on Apr 24, 2007
What is the model number (and Windows 7 driver) for Acomdata external hard drive serial number AC07111300220
  • 1Connect the Acomdata external hard drive to your computer through the USB cable that came with the drive.
  • 2 Click the "Start" button on your computer screen and then click on the "Control Panel" tab.
  • Sponsored Links
  • 3 Click on the "System" button and then click on the "Automatic Updates" tab if you are running the classic view. If you are running the standard view, click on the "Performance and Maintenance" button and then click on the "System" tab.
  • Read more: http://www.ehow.com/how_6880582_troubleshoot-acomdata-external-hard-drive.html#ixzz345dOHa31
    got it by just searching and a whole buch of solution came
    May 05, 2014 | Acomdata Computers & Internet
    Trouble with my Acomdata external hard drive and my mac
    Unfortunately it seems that Acomdata is no more on businness.
    In order to get support you can try writing an email to techsupport@acomdata.com
    Feb 04, 2013 | Acomdata Computers & Internet
    Acomdata external hard USB hard drive model HD160UE5-72 worked fine then suddenly the device was not recognized. Reboot with unit powerered up and the device is not detected. Blue LED is on, tried...
    Either the hard drive is bogus or the electronics of the external adapter is the culprit. Take out drive and hookl directly to mo bo as a secondary drive. If recognized drive is ok and the box is at fault.
    Aug 25, 2017 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
    I am having a problem with my external hard drive I look over and the blue light is good on the Acomdata D32OUFAPE5-72 Hard drive and then I go to explorer and it is no longer in my directory as a...
    You can remove the hard drive from the case and put it into another, new usb hard drive case. You can buy one for 20-30 dollars. I have seen this many times before. The hard drive is probably okay, but the controller inside the acomdata case is likely dead. Don't worry, just get a new usb hd case.
    Hope this helps!
    Regards,
    Joe
    Jan 04, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
    Acomdata 250 external (SATA) hard drive not showing up on desktop
    be safe
    go on line to acomdata web site and down load the driver from there
    Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
    I can't seem to open my external acomdata hard drives. My computer doesn't recognize them and when they do open they will close in a few minutes.
    Either the power-supply for the external drive is dying,
    or the disk-drive inside the external case is dying.
    Quick, make a "backup" of all the files on your ACOMDATA, before it totally "dies".
    If it still is under warranty, exercise the warranty, and replace it.
    Nov 13, 2009 | Iomega HDD External Desktop (32660) 80 GB...
    I need to replace the dura micro dm5133u ac adaptor for my acomdata external hard drive.
    Now, if you can't find an external hard drive adapter for your drive, can I ask you is it for a laptop or desktop.
    If it is for a desktop, you can actually open the drive casing and take out the internal hard drive and plug it into your computer.
    Sep 30, 2009 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
    Problems with Hard Drive
    Appreciate the direct "Ask Me".
    T your concern:
    • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
    • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
    • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
    • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
    • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
    • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
    • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
    • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
    • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
    • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
    • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
    • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards. Thank you for using FixYa.
    Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Installing old drive into new drive
    If the problem is in the controller inside the case which in 99 percent of the times it is, This will certainly fix your problem. The MTBF(mean time between failure) of harddrives is 100,000 hours of operation. Also, any external case can be used that matches your hard drives specs...size, IDE, SATA ect...
    Hope this helps you,
    George
    Jun 22, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
    Open Questions:
    Acomdata HD250U2FE-72 (hd250u2fe72) 250 GB Hard Drive Logo
    217 people viewed this question
    Top Acomdata Computers & Internet Experts
    Donna Sander
    mark
    mark
    Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
