Question about Panasonic PT-53WX42 53" Rear Projection Television
Screen Distorded My PT-53WX42F was hauled in a pickup truck backwards. Yep, facing the wind. Needless to say the screen blew in. I removed the front and all the brackets, reinstalled the screen (2 pieces of plastic) and the brackets. The screen seems floppy and when you watch it, it looks like your looking through a tube. The center is clear in a circle but the rest is blurry. Did the screen need to be glued in prior to the holding brackets being installed? Any help would be greatly appreciated. Dennis
    New Friend:
  • 21 Answers
You're either missing a piece of the screen or something's installed wrong. The order should be 1: front protective screen 2: the lenticular, and 3: fresnel lens.
All is supposed to be assembled with double sided tape, one being a special ultra-thin clear tape. DO NOT USE GLUE
Good luck, Mark
Posted on Nov 28, 2008
PT-53WX42F Panasonic Cinemavision Fresnel / Lenticular screens for cheap
That was an expensive mistake, sorry to hear about it.
I checked with the factory and not all 3 parts you need are available any more... Unless you can find someone junking a similar set with a bad chassis, you may have difficulty fixing your's.
Good luck in your search.
Mark
Nov 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
Aug 05, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic 47 inch Projection tv PT-53WX42F
Sounds like your convergence chips are going. Unless you are real handy with soldering iron I would suggest having a tv repair shop service it(probably cost $200-300). If you are handy then I believe the chips you need are Sanyo STK392-110. There should be 2 of them. be careful if you order them online, there are lots of chinese knock-offs out there.
Apr 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Streaks
It's called tearing and it's likely in the HV circuit, possibly the FBT or splitter. Won't go into any greater detail than that, other than to say it's time to call the technician. Voltages in that circuit can make you VERY dead...
Bill
Mar 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Resistor
electronix.com or matelectronic.com should have that resistor. Be sure to specify flame resistant 5% tolerance that is a convergence resistor so it needs to be flameproof and install it up off the board like the origional was.
Feb 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Screen will not come on
Can you tell me how many times the light flashes or is it constant flashing/ It should flash a number of times, pause then flash all over again. Let me know what its flashing.
Jan 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT= 53WX42F
Does it blink three times if so its a convergence problem -your set uses stk392-110 i usually replace with stk392-150 or stk392-180 these are more stable. if you have no soldering experience or electronic experience. but if you want the challenge go for it. remember that there can be several thousand volts in this set even when unplugged.
Dec 12, 2007 | Panasonic PT-56WX53 53" Rear Projection...
Real projection tv model# pt-53wx42f
you need to replace (2) STK392-110s some are 120s 150s up grade to 180s.Also after you replace them you will have to do complete alinement of convergence in order to do this you must have service codes.
Dec 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX42F Picture Problem. Color Distortion.
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
79 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
