Question about Garmin Forerunner 305 GPS Receiver
Elevation stuck at 20000m. Grade and total ascent not working.
The problem occured after cycling in the rain. All other data workink ok. It is outside guarantee.
  • george252 Nov 18, 2008
    I do not think so since all other data are working fine. I cycled in the rain in the past with no problems.
    when you say open the gadget what do you mean? How do I open it?
    President:
  • 2,712 Answers
It can be reset by pressing the 'Mode' and 'Reset' (lap) buttons at the same time.
In addition, please make sure that the device has the latest softwareversion available. To update the software, please use the followinglink:
http://www.garmin.com/products/webupdater/
Or try the following with the unit switched off.
  • Press and hold the mode button whilst powering up the unit.
  • You will see a message "do you really want to erase all user data" select yes.
Once you have done this leave the unit with a clear view of the sky to update a fresh almanac.
Posted on Nov 18, 2008
    Genius:
  • 1,142 Answers
Yes it is outside warranty you can check for more details click on this link
http://www.garmin.com/garmin/cms/site/us/support/
Regards
  • 1,512 Answers
Hi, I would remove the battery, overnight to reset the unit, and get a new seal for the unit,or take it to a watch repairman and have him fit a new battery and seal to it for you. He will also clean the switches and so on, return case integrity to the unit. Happy to talk to you more about it.
regards
robotek
    Sergeant:
    Champion:
  • 283 Answers
HI,
- Open the gadget
- Look for a moist in the main board and clean it using a lighter fluid and a tissue.
- Use a dryer and dry it well.
Please dont rate me if not satisfied with my suggestions. Thank you for using fixya..
    Genius:
  • 1,847 Answers
It is quite sure the water might have gone into the unit that might be causing it.
  • Legin Varghese
    Legin Varghese Nov 18, 2008
    I think you should take the battery off the unit and then use the hair drier to dry it completely.
    hope this will fix the issue.
  • Legin Varghese
    i want you reset.
    Turn the unit off.
    If you cannot turn it off, due to a "lock up", leave the system
    the drain the battery.
    With the unit "OFF"
    Press and keep holding
    the "MODE" button
    the "POWER" button
    Release the "POWER"
    button
    Release the "MODE"
    button
    The unit will ask
    if you are sure you want to perform a full reset (you will loose all
    stored data)
    Reply by pressing
    "ENTER" button.
    The unit has now
    been reset.
    Let me know the status ....Kevin.
How do I calibrate elevation grade for treadmill?
Hey there, sorry to hear you're having an issue with your elevation motor. I would be happy to help you solve the problem.
Since you already installed your motor you can go straight into diagnostic mode.
To get into Diagnostic Mode on your L8
Make sure to turn off your treadmill.
-ET's - Press Menu and Start at the same time
-CT's - Press Manual (or Display^) and Start at the same time
-All other L SERIES mills - Press Display (or display and Start at the same time
SideNote-
-*CT's that were manufactured after 09/2003 - Press Display and start at the same time.
Few things you want to do, if you haven't already.
A. Align the motor with the clevis mount and install the motor mounting pin.
B. Insert hitch pin.
C. Reconnect the elevation harness to the lower board
D. Set the lowest limit switch by holding the UP elevation button for 5 seconds. Then press and hold the DN elevation button one more time to make sure you only hear a click.
E. For L7/L8 machines; Thread the elevation nut to where its flush with the threads on the "worm' shaft.
F. Mount the elevation nut to the leg assembly by lining up the holes on the leg assembly. You may have to move the leg assembly so that the holes on the elevation nut line up. Then slide the two elevation pins through the elevation assembly and into the elevation nut. then secure the pins with the 2 set screws.
To calibrate your potentiometer you can try to adjust while it is installed but for best results you must calibrate it before its in your motor housing.
G. Calibrate the elevation potentiometer and to do so you must;
1st: Visually confirm treadmill is leveled. (0% grade)
2nd: Adjust the settings as follows;
All L SERIES millls should read 0.0
3rd: If the setting is incorrect, follow these steps.
Step 1: Turn the post of the potentiometer all the way
CLOCKWISE.
Step 2: SLOWLY turn the potentiometer COUNTER
CLOCKWISE until the setting is correct.
H. Carefully install potentiometer into the motor housing
*NOTE: The setting may vary when inserting the potentiometer
into the motor. As long as the change is minimal, fine
adjustment can be achieved by rotating the meter
while inside the elevation motor.
I. Press OFF to turn treadmill off. Then restart the machine in manual mode to TEST elevation after resetting your potentiometer. As long as the change is minimal, fine adjustment can be achieved by rotating the potentiometer while inside the elevation motor.
For more Diagnostic features and possibly further detail, I will be attaching a Link to your machines service manual. I hope this helps, always hear to help. SportSmith.
http://www.sportsmith.net/images/product_support/landice/Manuals/Service/P0472050%20L%20Series%20Service%20Manual.pdf
Apr 20, 2015 | Landice L8 LTD Cardio Trainer Treadmill
What does the Altimeter measures?
The Altimeter measures elevation of your ride. It is useful if you are training for a race and you would like to keep record of your highs and lows.
Jan 14, 2013 | Cycling
Efx 546 in diagnostics mode, flashes 255 and then real position of incline. getting error 42 when first turning machine on.
ok
elevation needs calibration or stuck
open--put elevation manually lowest and turn the unit on and bring the elevation lowest by pressing el down key
put it together clear it and start elevation will come in the starting position clear it and use it 225 is out of range of elevation
also check elevation fuse if it is good and secure
Nov 20, 2010 | Precor EFX 546i Elliptical Version 4
Home a/c intermittent during rain
You need to check the contactor. It sounds like the contacts may be getting close to the end of their usefulness and they are welding themselves closed. Check that and let me know what you find.
Jul 29, 2010 | Heating & Cooling
I have an ascent wireless 9 computer and it won't recognize the sensor. Could it be that it needs a new battery? i just took it out of the package yesterday. i had this problem with my last ascent computer...
INSTEAD OF GIVING THE ASCENT COMPUTER 9 AWAY YOU SHOULD HAVE KEPT IT TO WORK ON YOU'R SECOND COMPUTER FOR PARTS YOU'R DIGGING A DEEPER HOLE.
MY ADVICE IS BRING ASCENT COMPUTER BACK FOR A REFUND OR CREDIT AND START OVER AGAIN.ONE THING YOU CAN DO IS YOU GO ON LINE LIKE YOUTUBE AND ASK
WHAT COMPUTERS HAVE BEST REVIEWS AND TAKE IT FROM THERE....MAKE A PLAN.
D,R.CLAUDIO
Dec 11, 2017 | Cycling
Treadmill wont work
Error Code: Grade potentiometer out of range (PO error)
Meaning: error detected in the elevation system you need to recalibrate the elevation potentiometer You can find a qualified technician or send me an email to cardiotech_me@hotmail.com to explain the steps.
Jul 05, 2010 | Landice L 7 Club Cardio Trainer Treadmill
There is no "climb data", elevation gain when I download to Ascent software.
Hello. you may need to go to garmin.com/drivers and download a new driver into your computer before you use that software again. Joe
Mar 22, 2010 | Cadence Garmin Edge 705 Bundle [heart,...
Total elevation gain consistently way too high (20+ percent)
I have the same garmin, and have the same problem.
The high changes even during flat runs so when added you have this overamount of climbing.
I just reduce the points of the track and then the addition is more accurate.
My problem now is that the GPS stops working during runs (turns itself off). Awful!!!
Aug 03, 2009 | Garmin Edge 205 GPS Receiver
ETX125 PE new model. Elevation has totally stopped.
Could be that the DEC motor driver has died. That could be verified by swapping the connections between the RA and DEC. If the DEC now moves, then that is the problem. If not, then the DEC motor is bad.
Nov 17, 2008 | Meade ETX Premier Edition: ETX105 PE...
Garmin Forerunner 305 GPS Receiver Logo
75 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
