Question about Sanyo AVM-2509S TV
My tv is fine last time i checked, now it wont turn on. ITS BLUGGED IN AND EVERYTHING!
It is my ssisters tv, we moved it downstairs when she went to college. but all of a sudden it wont turn on when we try to. i have no idea what it could be. the only thing that might have happened is that it could have been dropped. i removed the back part of the tv to look inside, and the antena in connector was smashed in. but the funny thing is is that that is the only thing that would hint to it being dropped. so i have no idea.
    Sergeant:
  • 337 Answers
You have an indication the unit was dropped ,if that is the case the unit might have a broken circuit board,a crack on the very edge of the circuit board or somewhere in the center where the heavy components are.If you are familiar with tv service you can likely find where is broken but repairing that section is what becomes difficult,sometimes the traces are very thin and it can not be repaired.If you are not too familiar with tv service you should seek the help of a professional only for an estimate. Let Us know if you need more information.
Posted on Dec 06, 2006
  • Omar Urrutia
    Omar Urrutia Dec 06, 2006
    Your rating response is also important.
I have a foxstat -HDR humax box and I am getting no or bad signal on the TV downstairs. I can get some channels but not all.
I suspect that the box upstairs is a Freesat box; a Freeview box requires a feed from an aerial, not a dish.
The problem you are seeing may be caused by water in the cables, if they are not sealed at the LNB. The LNB may be failing, but dish misalignment is more likely.
As there is an unused output on the LNB, try swapping one of the feeds with a poor signal to it.
Jul 27, 2015 | Humax Televison & Video
No sound
the s video is only for video, you must also have a red and white rca cable connected also
Feb 23, 2012 | Televison & Video
I moved our computyer from downstairs to upstairs.
Power supply is bad,,
You can try to unplug the main motherboard plug, then plug back in,, It should last as long as it stays pluged into the wall.
Keep it pluged in when you do this,,
Nov 30, 2009 | HP Compaq Presario SR1410NX PC Desktop
TV wont turn on with power button or remote
Try putting the cables back where they were. After that re-route them again but this time use the manuel.
If that doesn't work, consult the TV's manuel.
Jul 04, 2009 | ViewSonic N3735W 37 in. LCD TV
TV wont turn on. Standby light blinking 7 times in sequence.
It will most likely need the power on switch replaced its very common
Jun 21, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
A/C blows weak/low volume of air through vents
I f it is fan that has more then one speed if you run it all the time,it may
not be on high sample : low fan speed runs all the time
med fan speed for heat
high fan speed is usually for air conditioning so if everything is good then it maybe the relay.
May 02, 2009 | Carrier Heating & Cooling
Xbox 360 wont work on my Tv now - always been fine before
Hi...
Make sure the switch on the 360 A/V cable is in the right position. Also unplug everything from the unit and plug it all back in again.
From the reading I've done on tech issues the 360 has a lot of temporary issues like that.
Jan 02, 2009 | Microsoft Xbox 360 Console
TURNED TV OFF AND NOW IT WONT COME BACK ON
the power supply of your tv has a problem,its better to coldsolder the main board of your tv.
May 04, 2008 | RCA TruFlat 27F520T 27" TV
Frigidaire Dryer hums wont turn on
motor-overheated. you might make sure the vent is clean.
Jan 05, 2008 | Dryers
Issues with picture after moving Toshiba 50HX81 - picture is bad
i would check for loose connections by the convergence amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 25, 2007 | Toshiba 50HX81 50" Rear Projection...
Sanyo AVM-2509S TV Logo
50 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
