Question about Technics Audio Players & Recorders
Technics SL-B2 not cooperating with R4450W Soundesign receiver
So i've had some back luck trying to find a cooperative record player in the past couple months. the first replacement system was this unit built into a cabinet i found at a second hand shop. it came with all the manuals & is apparently from JC Penny [early 80's i would assume.]
the motor is a bit off, and plays at probably 38 instead of 33rpm.
now you're probably wondering 'why would this fool purchase a record player that plays fast?' ... i dug through their stack of records & the only thing i recognised from the pile was Rush.
the 45 setting is better, but now i'm set on replacing the record player in the unit. i'd like to keep the receiver, as that seems to work just fine.
i recently came across a Technics SL-B2 at Goodwill for $10 & i absolutely caved.
i've already replaced the busted needle with an Audio-Technica AT90.
the most obvious issue with is is that it needs a belt...that's easy.
the less obvious issue with it is that i am having some issues getting it to hook up to the receiver.
the receiver is by Soundesign with the model number R4450W.
at this point i will take any sort of advice!
    Problem Solver:
  • 8 Answers
Hey , Why not try using the cartridge from the old recordplayer on your Technics ? This should solve your problem with no money to invest.
Good Luck.
Posted on Feb 09, 2009
  • 4,234 Answers
I would suspect that the receiver has only an AUX input. If that is the case, you will need to purchase a phono pre-amp. These are readily available for about $20 or so. This will boost the low signal level from the table to line level which is what the AUX input is expecting.
Dan
Posted on Nov 18, 2008
I have a technics SL-CH505 compact disc but it will not play burnt CD;s any suggestions my other technics SL PG 400A plays them noproblem
The Optical Pickup(laser) may be weak. It takes much more power to record than play, which I guess it works.
Oct 13, 2014 | Technics Audio Players & Recorders
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Audio Players & Recorders
Where can I purchase a Technics SL - B2 turntable belt? John Maxwell
try MCM electronics supply. (MCMelectronics.com) You might have to buy a kit of assorted belts or ten belts. MATelectronics is another supply house.(matelectronics.com) or google SL-B2 turntable belt.
Jul 28, 2010 | Audio Players & Recorders
Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
Jan 16, 2009 | Yamaha RX-V463 Receiver
Minidisc player 2003 mini cooper
all minidisks are standard no different sizes, ebay may be your best bet,but you'll need a minidisk recorder to put music on to them
Jan 03, 2009 | 2003 Mini Cooper
Adjustments on Technics SL-B2 Automatic Turntable
the pitch is just the speed, adjust to your liking.
"How do I adjust tracking pressure and anti skate?
If you are lucky enough to have these two adjustments here's how: Move tracking force counter weight till needle suspends/hovers above record. then rotate numbers to zero. (this is zero grams pressure on record) then rotate weight AND numbers to recommended tracking pressure for your needle usually 1.5 to 3 grams is average. Then rotate anti skate to be equal. That should get you there. If you still have adjustment related distortion then it may be time for a new needle.
NOTE: Anti skate is adjusting side to side pressure WITHIN GROOVE of record. Tracking pressure is how hard the needle is pushing down inside the groove." from
turntableneedles.com/FAQs_ep_33.html
lots of crackles are caused by crummy records and needles. to some small degree are unavoidable no matter what, but above all the records must be clean.
someday the manual may show up for free here
http://www.vinylengine.com/library/technics/sl-b2.shtml
Dec 02, 2008 | Audio Players & Recorders
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
Record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Apr 13, 2008 | Technics SL-1200MK2 Turntable
Using Technics SL-B2
check the antiskating. then i don't know.. maybe the tonearm has to be calibrate
Feb 18, 2008 | Technics SL-1210 Turntable
142 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
