Move laptop while running it turns off! doesn't turn on without power cord plugged in.
    Novelist:
    Scholar:
  • 84 Answers
What i understand from your post is when you are doing some work on your computer in which the system is not connected to a power adapter it turns off.
It is possible that your battery is not holding charge from the power adapter. If that's the case you may need to check with your computer manufacturer if the battery still under warranty for replacement.
Let me know the type of system you have as well.
Keep me posted.
Thanks.
Posted on Nov 18, 2008
My zoom g1xn suddenly stopped working. When i connect the power source, it doesn't turn on. . . When i tried batteries, i turned on but the display was flickering then it turned off. . . What is wrong?
Try another cord/charger. Check the AC jack in the machine. Is the battery charging with the cord/charger plug in? Has the laptop AC jack been pulled by the cord? Damaged?
Dec 11, 2012 | Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My laptop doesn't turn on. I thought it might be the power cord but that is not the problem. I guess the problem lies where you plug the power cord into the laptop. I gently wiggled the cord and the...
Hi
The normal problem is with the power socket in the laptop. Try to check the adapter first with other working laptop and later you can open the laptop to fix the problem.
Explaination
Normally the power socket gets loose as you keep the laptop connected and move it or adapter connected to laptop and you suspend it from the wall socket. This is a cold solder with the socket in the laptop. Hence you have to open the laptop and re-solder the socket to make it work perfectly.
BEST OF LUCK
Be careful while opening always use anti static wrist band to avoid static damage to the motherboard and other parts.
Jul 15, 2011 | Computers & Internet
When i push the start button notebook doesn`t work.
* Make sure it's fully charged.
I've none of the above worked, try turning your laptop on without the use of a battery. So plugin your power cord and try that.
Jun 28, 2011 | Acer Extensa 4620 Notebook
Yesterday my battery was indicating it was at 17%, so I plugged it in. Awhile later the "battery low" indicator came on screen so I realized it hadn't been charging. It still didn't charge if I...
You have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 27, 2011 | Panasonic Toughbook CF-51 Notebook
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
You need to replace the battery as it has expired.
They are available by typing the battery model number or laptop model number into ebay or Google or indeed any search engine.
Hope that helps.
Nov 19, 2010 | HP Computers & Internet
HP Pavilion ze2000 Laptop won't turn on
Have you tried removing the battery and seeing if the laptop will then run?
Jan 18, 2010 | HP Pavilion ze2000 Notebook
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and without the battery, and when I plug it in it start's flashing in the front, but won't turn on.
Remove battery and disconnect power cord. Press power button for about 5-10 seconds (without battery and power cord) Connect power cord only then turn it on.
Dec 01, 2009 | Toshiba Satellite 2455-S305 Notebook
With power cord plugged in and without power cord plugged in the pc will not turn on
remove the battery, plug-in power cord then power on. your battery may be completely drain and your power adapter can't give enough supply to power up your laptop and charge the battery at same time. if doing so power on your laptop, charge your battery for about 12 hours without turning the power of your laptop
Nov 03, 2009 | ASUS EEEPC901-GP010X Netbook
Need instructions to replace the "carriage assembly" for ink cartridges on a HP 7400 OfficeJet All-In-One series printer.
  1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
  2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
  3. Looking in through either the print cartridge access door or the output paper tray, you can unsnap carriage by pry back tabs or remove screws, depending on the model.
  4. Make sure the print carriage is loose and can move freely. You can then remove the carriage.
    You may have to reach through the output paper tray to access the print carriage.
  5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
  6. Press the On button to turn on the product.
Oct 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Computers & Internet Logo
82 people viewed this question
Alun Cox
David Payne
David Payne
