Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Panasonic 47" rear projection faded pink square
I just replace my convergence chips and most of my problems were fixed. There is a faded pink square that overlays the screen except for about 4" on the left and right side. The picture is clear except for that. It is just a little anoying. Is there anything I can do?
  • 113 Answers
That is a unique problem. You might make sure that your mirror and lenses are clean and that nothing has fell in the way of the tubes. There isnt anything else that could come to mind that would cause this.
Posted on Feb 04, 2008
My panasonic cinemavision hdtv is showing double vision. How can this be fixed.
This is likely a convergence problem and if model number indicated here is correct set would need to have both of the stk-392-110 chips replaced and the set adjusted.
Let me know if you have questions.
Sep 10, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Colors overlap each other and looks 3d
This is symptom of bad convergence that happens due to failure of convergence output chips in tv, there are two big black chips attached with big aluminum heat sink that will be replaced to solve tv issue.
If you are not familiar with electronics stuff repair then call local tv repairman to replace above said chips to fix the problem.
Hope this will help.
Thanks.
Apr 05, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have problem with my convergence rear projection panasonic
most of the time you need to change the stk392-110 chips an ome resistors let me know if you need more help
Jul 31, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Replaced convergence chips, have new problem
Did you check the 2.2 ohm 2watt resistors? As often one or two will blow when the old ICs fail. The 3 blink error is indicating a problem with the convergence circuit still.
Jun 19, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 47 inch Projection tv PT-53WX42F
Sounds like your convergence chips are going. Unless you are real handy with soldering iron I would suggest having a tv repair shop service it(probably cost $200-300). If you are handy then I believe the chips you need are Sanyo STK392-110. There should be 2 of them. be careful if you order them online, there are lots of chinese knock-offs out there.
Apr 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem
replace the stk-392-110 (x2) and any burnt resistors. cost 20$
Nov 19, 2007 | Panasonic PT-47WX42 47" Rear Projection...
COLOR PROBLEM
Is the pic full? Or is this pink square full and the pic seem squeed?
Jan 03, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
