Question about RCA P56950 56" Rear Projection Television
Rca tv wont turn on
I have an rca ctc195 series. the tv wont turn on. I checked the fuse and it was fine. any help will be greatly appreciated thanks
  • Anonymous Nov 19, 2008
    I have the same problem when I plug the tv in it just beeps
  • Larry Otts
    Larry Otts Nov 19, 2008
    tv light comes on for 5 seconds and repeats this three times, but does not come on . it is aprox. 60 seconds before i can try again.
    mod.d52w19b
  • RCA Master
  • 5,138 Answers
What is your Chassis# and what year is TV??
Posted on Dec 27, 2008
  • tom latour Nov 27, 2011
    hi I have one of these. I cant get a picture. the sound is fine and even the menu options show up...just no picture. screen is bright silver. very weird.
RCA ctc195 series won't power on constant small beeping sound
if its a high pitched squeek its a short in the deflection circuit, a common failure part here was the high voltage transformer.
Dec 11, 2012 | Televison & Video
Dead
Check this site for some useful info: http://wa6ati.com/CTC195-197.html
Feb 15, 2008 | Televison & Video
20 inch rca colortrak plus wont turn on.trying to figure out where power relay is on board. any help would be greatly appreciated thanks kris
Dear Kris
You check the out put voltage of SMPS
If OK then check the Horz. out put Transistor / MOSFET
Check the Horz. driver TR.
Apr 28, 2011 | RCA 20" TV
TV is just beeping no picture/sound
I have looked through most of the answers to the same problem question and found my answer. I thank you very much for your site for the free info as the cost could have been huge to fix it. Now that I no the part the cost is minimal, and I can do it myself(with a little help from my friends).
Again Thank You
Kim Graziano
Jan 31, 2009 | RCA P56923BL 56" Rear Projection...
RCA TV
replace the fly back transformer,thanks.
Nov 08, 2008 | RCA F32650 32" TV
MY TV IS CLICKING AND WON'T TURN ON
Good Day;
The most common problem with these Models/ Chassis' is IHVT (intergrated high voltage transformer) going bad. They have around 99% failure rate. T14401 > part number > 239111 >IHVT.
Try to get RCA part a little more pricey but more reliable then after market ones. You can tell if it's bad by the crust on the top of IHVT.
Good Luck, big IRISH.
Sep 11, 2008 | RCA P52926 52" Rear Projection Television
Tv wont come on
do you have a chassis number? example PTK169PGB
CTC169PGB
Mar 26, 2008 | RCA P60921 60" Rear Projection Television
RCA P52940 Television
The P52940 uses the CTC195 series main chassis. The most common reason for the set not to start up is a shorted flyback (high voltage) transformer. The set actually does try to start, but the computer immediately detects the extra current drawn by the shorted flyback and instantly shuts the set back off. The chassis should be checked and the flyback replaced by a qualified tech familiar with RCA projection TV's.
Aug 12, 2007 | RCA P52940 52" Rear Projection Television
No power on RCA p60921
Replace the Power Supply switching transistor, If a CTC195 chassis it is the Q14101. Cost about $8.00 for part if you can do it.
Aug 04, 2007 | RCA P60921 60" Rear Projection Television
HELP TV WILL NOT TURN ON AT ALL
The fact that the picture was curved tells me that the pincussion circuit was faulty. If your not a tech then your gonna have to get a pro to assist you with this repair as everything is soldered in and theres no user replaceable parts in this set as they are all soldered in. If you know electronics then the most common parts for the set being dead would be the hi-voltage transformer and the horizontal output.. Also the small coil l401 has to be resoldered. Now for the pincussion circuit you gotta check waveform on base of tl81 for 13.7 vpp and if its not there replace IL81 and RL81. If its is there then check the transistor TL81 and TL82 & CL85. Im sure you will find on of them to be bad. Lke I said if your not a tech you can get a bad shock piddleing with this set. Good Luck
Jun 30, 2006 | RCA F32450 32" TV
RCA P56950 56" Rear Projection Television Logo
455 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
