Question about Sony VAIO RB30C (VGCRB30) PC Desktop
Sony VGC-RB30 won't start....
All connections are correct..........it power up but display on monitor
thanks
    Sergeant:
  • 237 Answers
First things first, you may have already done this, but sometimes it can be overlooked...check the settings of the monitor(I've forgotten this several times when I first owned a pc). Next, if the settings are correct and not on "black or white or whatever color your monitor is", check for any visible damage to your monitor, such as cracks, missing pixels, etc. If you see anything out of the ordinary with your monitor, try to swap it with a monitor you know works, and power it up. If the 'new' monitor works, then all you need is a new monitor!
Posted on Nov 18, 2008
Random Restarting Issue with Sony Vaio VGC-RB30
send it in to check the fan inside if not cooled it could shut down and start back up when cooled
Nov 29, 2013 | Sony VAIO RB30C (VGCRB30) PC Desktop
What graphics card can be installed in a Sony VAIO VGC-RB30 using Windows 7?
Hi Jose,
Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card. Is one of the compatible cards you can put in the system and can be sourced from
http://www.memorygiant.com/video-card/sony-vaio-vgc-vgcrb30-vgcrb30c/
Regards
Proton
Oct 02, 2012 | Sony VAIO RB30C (VGCRB30) PC Desktop
Installing random access memory in a Sony VAIO Computer
Sony VAIO VGC-RB30
Follow link and download the VAIO Users Guide. Instructions are on page 55 and 56. The manual states the maximum memory is 2GB PC-3200 SDRAM. Crucial.com states there are 4 slots total.
Sep 19, 2012 | Sony VAIO VGC-RB30 / VGC-RB30C 512MB DDR...
Vaio vgc-rb30 won't read reboot disc..says can't find hard drive
check bios setting n check hard rivers iz there if u can show hard driver the problem iz hard disk and cchang it
Sep 09, 2011 | Sony VAIO RB30C (VGCRB30) PC Desktop
I have Sony VGC-RB30 and after power failure it is don't start at all, I can heat clicking and green button at back is flicking, what should I do?
first you have to remove the 24 pin conncter to your motherboard from the smps and short the green and black pin and see wether the smps is working if not working change them if working remove the the four pin conector to the motherboard from the smps and switch on the computer if the processor fan is working connect back the 4 pin connector to your motherboard and switch on the computer if not working the power section in the mother board has failure you can get assistance from a chiplevel service personal
Mar 27, 2011 | Sony VAIO® VGC-RC310G PC Desktop
My screen keeps going off and I constantly have to press the screen on/off button to get it to work again. Also the screen apears darker for a few moments before returning to its correct lighting. I...
How long have you had this desktop? Is it still under warranty? If so, get a replacement. It sounds like your monitor is dieing on you. Also, check the connection to the port on the PC that it is fully and correctly attached to the monitor port. Also check the port on the monitor itself if it has one. If this doesn't correct the issue, see if there are updated drivers for your monitor. It's either your monitor is dieing or your graphics card is dieing.
Jan 12, 2011 | Sony VAIO® VGC-LS37E PC Desktop
When I try to start my VGC-RB30 (back from sleep mode or fresh start), computer comes on, but monitor doesn't (or I get the VAIO screen only). Yesterday, I unplugged the computer altogether, then plugged...
Check all of your adapter cards (PCI or AGP or PCIE) to ensure they are seated into the MB properly. As the problem seems video related double check the graphics adapter if it is a stand alone card. AGP cards can be tricky to seat properly on some mb's
Jul 07, 2010 | Sony VAIO RB30C (VGCRB30) PC Desktop
Hello Sony RB30 w/ sdm-hx93 monitor. Approx. 7
Blond and Baffled, (CD), it's okay, I believe you have a common problem.
The computer sends a video signal to the monitor. The monitor is working fine. Hence - No Signal.
Monitor doesn't receive a video signal within a certain specified amount of time, it goes to a Power Save feature.
Just enough power is used, to keep certain components inside the monitor at a ready state. (When it gets a signal from the computer, the monitor turns back on)
The problem is the computer.
Most of the computers that come to my shop have failed because the inside of the computer, and it's power supply have never been cleaned, or VERY rarely.
[Plus one more problem, stated at the end of this solution]
It's understandable, as a computer repair shop charges a slightly hefty price to do this, (Not myself),
and it looks like a daunting task to most computer users.
It isn't.
The computer is unplugged from power, computer case is opened, and a can of compressed air for computers, is used to spray out the inside of the computer.
(Power supply also)
As dirt, dust, hair, carpet deodorizer, (And other material foreign to the inside of a computer), build up inside the computer, this is what transpires:
A) The cooling fan, and heatsink for the Processor, become clogged with the above mentioned foreign material.
(This is an example of an average Fan and Heatsink,
http://www.directron.com/8w553b1m3.html
You can click on the images in the different views, to enlarge them)
In the link above the item that has many fins on it, is the Heatsink. The Heatsink sits under the fan.
The Heatsink functions like a radiator. The fins draw heat away from the Processor. (Processor not shown. The Heatsink is mounted to the top of Processor's case)
The fan draws air through those fins, which in turn draws the heat away from the Processor.
When the area in-between the fins is clogged with foreign material, plus the fan's blades, the cooling capacity drops tremendously.
This in turn allows the Processor to heat up.
The Processor has a certain thermal limit, and turns off when it becomes too hot.
It is a Fail Safe feature that is built-in. Keeps the Processor from burning up.
No processor running, no computer. Hence a No Signal to the monitor.
Solution 1, is to buy a can of compressed air for computers, unplug the computer from power, open the computer case, and clean the inside of the computer. (Also the power supply)
Should you like directions in how to do this properly, and if you need advice of how to open your computer case, please state so in a comment. (Believe top right of your page)
B) There is one more thing that transpires on a large percentage.
The Power Supply overheats also.
When the cooling fan of the Power Supply becomes caked with the above foreign material, it heats up. As the power supply heats up, tries to put out more power.
Heat = Wasted Energy
Also, there are Heatsinks inside the power supply that become clogged)
Eventually, the power supply components inside the power supply, fail.
Solution 2 is to replace the power supply.
If Solution 1 does not fix the problem, then I advise it's time to try Solution 2.
Should you need guidance to do this task, please reply in a comment.
(Tip: Once you rate a solution, you can no longer post a comment)
This link, states the specifications of the Sony Vaio RB30 Desktop PC,
http://www.superwarehouse.com/Sony_VAIO_RB30C/VGC-RB30/ps/471790
Jan 07, 2010 | Sony VAIO RB30C (VGCRB30) PC Desktop
VGC-RB50 Display Problem
I hate to be the bearer of bad news, but I think that the MB or the processor just took a dive on you. Most likely the processor... as you are able to power up. If it were the memory or the video card, you would hear a series of beeps when trying to start the computer. And you already verified the monitor is fine.
Jan 03, 2008 | Sony VAIO VGC-RB50 PC Desktop
Sony VAIO RB30C (VGCRB30) PC Desktop Logo
175 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
