Question about Maytag MED9600S Electric Dryer
Maytag Epic Dryer won't start!
Four days ago our Maytag Epic Dryer worked fine. Today, I put a load in and it wouldn't turn on when I pushed the "Control On" button. The light inside was still working.
I realized I could get it to turn on by pushing the "Control On" button and spinning the dial at the same time. Every time it would turn on at the "Touch Up" option, no matter where the arrow was at the time.
However, pushing the "Hold to Start" button DID NOT turn it on. We've unplugged, replugged, flipped the breakers (which had not turned off in the first place, but did it for good measure), taken it apart, tried to reset the computer by holding down the "Off/Pause" button (but nothing happened), and un/replugged all the connections on the PC board (computer/control panel) -- nothing is working!
We need your help! Step by step directions would be most appreciated!
Thanks!
  • 1 more comment
  • cjarm22 Nov 18, 2008
    Also, no error flashed. And EVERY button you push when it's on makes the "Extra Care" light turn off and on.
    And yes, the door is completely closed.
  • lowell1500 Nov 28, 2008
    dryer does not turn on even though I've done all the resets. Light inside is on when I open the door, so I'm getting electricity.
    No lights on the control panel.
  • 31 Answers
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
Your motor has fried. It isn't in the Control Panel, the SENSES light wouldn't turn on if it were the CP. If you go to your closest Home Depot, ask the front desk for assistance with Dryer Motors. They will guide you through to get you the right one. They will even tell you how to install it. When you replace it with the new motor, the Dryer will work fine.
If this helps at all, please rate this a FixYa. - Evolution
Posted on Jul 17, 2008
  • 409 Answers
SOURCE: Maytag Epic dryer won't start
hi there,
if it beeps it means that the keypad is sending a signal to the control board to start it but it doesn't. since the control board sends a signal to the motor to start the dryer to spin. does the dryer hum?
Posted on Dec 17, 2008
bozcro
  • 867 Answers
SOURCE: Hello, today our dryer won't run. The control
if nothing works,belt may be broken, cutting of power via safety switch. check belt
Posted on Aug 08, 2009
  • 122 Answers
SOURCE: Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
Posted on May 20, 2010
heatman101
  • 43501 Answers
SOURCE: My maytag neptune dryer won't start. The control
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 01, 2010
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Maytag Epic Electric Dryer will not start, turns on and when you push the start button it gives me a series of beeps and then the lights by the different cycles blink, but will not turn on. Was working...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 17, 2011 | Maytag Dryers
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
heatman101
Jun 30, 2011 | Kenmore Dryers
"Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
Apr 25, 2009 | Maytag EPICz Electric Dryer
Epic z front load washer will not start
Maytag service came out and told me it is control panel Part# W10217425. I washed 4 loads 1 day and came back 4 days later and got 1 load done. Then it wouldn't start and they won't replace. I got mine at Home Depot but, Maytag won't replace. They say it has to break 3 times before they will replace. After Maytag sent someone to fix and they said they had to order part and didn't know when they would be back. I called Home Depot and they overnight sent me part. Now Maytags service says they cant come back for a week and if I put in myself I lose my waranty. If you don't have waranty anymore, I found at Sears parts for $12.45 for board.
Feb 01, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Maytag Epic Front Load Dryer
When you close the door it needs to click twice, the light will go out once its all the way closed........then your good to go
Jan 26, 2008 | Maytag MED9600S Electric Dryer
Flashing "touchup" and dryer won't start
This unit should be on warranty, call back the seller for service.
Nov 08, 2007 | Maytag MED9600S Electric Dryer
Maytag MED9600S Electric Dryer Logo
196 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
