Gateway T6836 notebok PC- how to use the camera? Just got this pc last week & can find no instructions on how to use this, correctly. Please help!
  • seeking128 Nov 18, 2008
    Thanks, sybabe. This pc is a laptop using vista, having this web cam built in. Went to My Comoputer, as suggested, but could find no help here, either. As you, cannot find manual. Please, what should be done?
    Thank you, again!
  • seeking128 Nov 20, 2008
    Thanks for your help, sybabe. Went to the store where this Gateway was purchased, asked for a manual. The man here said manuals are now built-in; not on paper, but on line. Whew, what a hassle! This will take more time, but this is what it will take. Thank you, again, no matter.
    Sergeant:
  • 237 Answers
I am shooting in the dark here, but seeing how I cannot find the manual to this notebook, and guessing you are using Windows 2000/XP, Go to the My Computer icon, double-click on your harddrive, search for program files. In there should be the name of your webcam software (indicated by some sort of webcamish name). I hope this helps.
Posted on Nov 18, 2008
  • zabrina liang Nov 18, 2008
    Ok, let's try going to the Start menu, Programs, and Accessories. Or Programs, and check the list of programs you have available and look for the webcam software.
  • zabrina liang Nov 20, 2008
    Hi, I'm sorry if I said anything inappropriate. I'm not sure what it is, but could you do this for me: Go to the STart menu, Programs, and give me a list of all the programs available.
    Do the in the Accessories folder.
    One thing I could think of doing if you are in a hurry, is to go to the Gateway website, and look for your webcam driver there. Look under your specific notebook, and it should give you options for support and download. I hope this helped a little more!
Gateway t6836 mouse button does not work
Replace Touchpad assembly, or use an external mouse
The left-click carbon button switch is worn out
Regards,
joecoolvette
Feb 12, 2013 | Gateway T-6836 Notebook
HI,i think my laptop gateway MD7820U is got virus & does not run correctly. How can i restore to the manufacturing default?Please help. Thank you, Tony
If you want to return the state of the pc to the day you purchased you will either need to use the recovery partition or recovery disc.
Recovery Partition:
  1. Hold down the ALT key and repeatedly tap f10 as the computer boots up
  2. Choose restore from recovery partition
  3. Follow onscreen instructions
Recovery Disc:
You can find full instructions for this process at the following link:
http://support.gateway.com/s/software/misc/7515219/7515219si9.shtml
Sep 14, 2011 | Gateway Computers & Internet
Cannot link vpn. direct from internet provider works. when try connection via d-link dir625 does not connect. does allow internet access
Ok to Setup you VPN follow the instructions below. You can configure DI-804HV, DI-808HV, and DI-824VUP+ by web management interface. Type 192.168.0.1 (The LAN IP is 192.168.0.1 by default) in the browser, and then input user name: admin (there is no password by default) to pass authentication of web management interface. Then finish the configurations as showed below on Gateway A and Gateway B. Configurations of Gateway A 􀂾 Model: DI-804HV (DI-808HV, or DI-824VUP+) 􀂾 Firmware version: v1.40 (You can download the latest firmware on D-Link’s website.) 􀂾 WAN IP Address: 14.15.16.17 (Static IP) 􀂾 LAN IP Address: 10.5.6.1 (Subnet Mask: 255.255.255.0) 􀂾 VPN Configurations: 􀂄 Enable VPN function on Gateway A. 􀂄 Tunnel Name: toGatewayB 􀂄 VPN Method: IKE (Main mode) 􀂄 Local Subnet: 10.5.6.0 􀂄 Local Netmask: 255.255.255.0 􀂄 Remote Subnet: 172.23.9.0 􀂄 Remote Netmask: 255.255.255.0 􀂄 Remote Gateway: 22.23.24.25 􀂄 Pre-share Key: hr5xb8416aa9r6 􀂄 IKE Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 28800 􀀹 Life Time Unit: Second 􀂄 IPSec Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encapsulation Protocol: ESP 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 3600 􀀹 Life Time Unit: Second 4. Verify the VPN connection Before you start to establish VPN connection between Gateway A and Gateway B, please make sure the Internet connection between Gateway A and Gateway B is workable. You can use “Ping Test” tool on Gateway A (or Gateway B), and input the IP address of Gateway B (or Gateway A) to see if there is any response from its peer device. Connect a PC (called PC_A) to the LAN port of Gateway A, and connect another PC (called PC_B) to the LAN port of Gateway B. Start to “Ping” PC_B on PC_A, then Gateway A will start to establish IPSec connection with Gateway B. If you can get “Ping” responses from PC_B on PC_A, then it means the tunnel has been established successfully. You can also check the “VPN Status” page with web management interface to verify the status of VPN connections. Figure 1: VPN status of Gateway A after IPSec connection has been established. Figure 2: VPN status of Gateway B after IPSec connection has been established.
Hope this helps
Here it is in PDF.http://www.vpnc.org/InteropProfiles/D-Link-DI.pdf
Feb 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
I need to reset my bios password on my Gateway T6836...does anyone know how?
hi
1} visit the website to recover your BIOS password
http://www.pwcrack.com/bios.shtml
OR
2}it is very risky to unlock it on your own .it involves shorting of pins on the motherboard (remove the Cmos battery and put it after 1min)
clear the password
Dec 22, 2009 | Gateway T-6836 Notebook
One of our customers bought a refurbished laptop, this person doesn't know much about how the function key works. Is there a instruction manual that I can print off for her? I hope you can help. thanks
hello there:
you can try to contact the gateway technical division and they should be able top give you their web link fot this ok if not please try these
  1. Search results for "acer acer laptop pc" laptop pc, printer manuals, user guides, instruction sheets, manual ... Please help me find the manual for Gateway NV5214u PC Laptop. Sharp Fax Machine UX-108 ...office.manualsonline.com/manuals/.../acer_laptop_pc_product_list.html - 60k - Cached
  2. Calculator manuals, user manuals, owners manuals, how-to instructions ... Please help me find the manual for Gateway NV5214u PC Laptop. Sharp Fax Machine UX-108 ... instruction manual. Canon All in One Printer PIXMA MP210. manual needed ...office.manualsonline.com/manuals/device/calculator.html - 59k - Cached
  3. User manual GATEWAY - User guide GATEWAY - operating instructions ... Where is my user guide? Download user guide, user manual, owner manual and instructions guide GATEWAY - Laptop, Notebook, Tablet PC & Docking Station.safemanuals.com/brand-user-guide-instructions-owner-manual/GATEWAY - Cached
Sep 18, 2009 | Gateway Computers & Internet
My desktop PC is a Gateway GT5656. The power
Could be try putting your power LED on your HDD LED header on your mainboard and then look at this while booting up and this will tell you if its the LED or the Header on your mainboard
May 03, 2009 | Gateway GT5654 Desktop PC
Sound problem
Has the audio output been muted? Check for that.
Sep 06, 2017 | Gateway M275 Tablet PC
Pc web camera 1.3mb for lg notebok is not working
have you installed the correct drivers for this product?
Nov 15, 2008 | Computers & Internet
Computers & Internet Logo
265 people viewed this question
Alun Cox
David Payne
David Payne
