Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
My whirlpool du1050xtps3 makes a grindin sound
The dishwasher has been getting progressively louder over the last several weeks. Do dishwashers have bearings which go bad periodically?
  • 473 Answers
Yes, this is common. Sounds like bearings in the motor. Will need to replace the pump and motor assembly. 14 6324 -->My whirlpool du1050xtps3 makes a grindin sound - partimage.aspx?imgid=z3bqljbfahrfmduxntm1oc9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Pump and motor assembly, complete - Original Whirlpool Part. Fits Whirlpool and KitchenAid dishwashers. This dishwasher pump and motor kit comes pre-assembled for easy installation.
Part Number: AP3778061 made by WHIRLPOOL $173.71 In Stock
Order now and it will ship Today
questionmark.gif This is the part with picture from http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136316. Look in your owners manual because some models cover this part for 2 yrs. Hope this helps.
Posted on Nov 18, 2008
Why is my Whirlpool dishwasher (GU1500XTLS) making a loug noise during a drain, wash and rinse cycle?
Could be a bearing, but it could also mean something ggt past the intake screen at the bottom and was pulled into the impeller. Turn off the power, remove the screen and inspect the impeller intake for any obstruction and remove it.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
I have a Whirlpool "Estate"
You need a new wash pump ... the sounds will get louder and louder
Mar 22, 2011 | Whirlpool Dishwashers
GU1500XTL loud humming sound during the cycle, getting louder
The run capacitor on the main wash motor needs replacing. Eventually it will just hum and overheat instead of rotating, so better replace it now before it overheats.
I doubt you can acces it easily yourself, as it may be away from the motor, and have to be tracked down.
Aug 05, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Water remains in Whirpool Gold Quiet Partner dishwasher
sounds like an issue with the drain pump, disconnecting the drain hose fromm the trap and run the unit, pointing the disconnected drain hose into a bucket. You should get a fairly strong stream of water until most of the unit has drained, if not you either have a blockage or ,with the grinding sound, a bad pump.
Mar 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
16 year old whirlpool dishwasher model no. DU8950XY-0
Sounds like it is a bad door seal. Recommend replacing the door seal and making sure the door is shutting square and not bent.
Jun 25, 2017 | Whirlpool Dishwashers
Kitchenaid Dishwasher - LOUD
i've found that if a glass or a dish breaks little pieces get caught in the grinder that is built in with the motor in time it will go away.
Jan 25, 2008 | Dishwashers
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
627 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
