Question about Cameras
AF function stopped working
Lenses will no longer auto focus. Cleaned contacts with eraser and alcohol and still not working.
  • 2 more comments
  • algrey Nov 18, 2008
    It will no longer zoom in or out automatically. I works on manual focus
    Do you mean the camera battery. My camera works fine. I have used it with other auto focus lens and they work. The lens just does not zoom in and out.
    I have four different camera bodies and the lens does not work on any of them. I have other lens that work on all the other cameras in the AF mode.
  • algrey Nov 19, 2008
    I have changed the batteries and uused compressed air all to no avail
    Sergeant:
    Champion:
  • 435 Answers
Hi, What camera is this? It would be better for us to know to be specific.
Did you try a firmware update ?
Also when kept in autofocus mode, try to force the lens little bit (gently) to zoom.
If it still doesnt work, you many have to find out in the menu settings. But to better help with it, we need to know what brand and model camera you have.
Posted on Nov 19, 2008
  • 541 Answers
Go to the website of the camera make and they will help you
Posted on Nov 18, 2008
    President:
  • 2,712 Answers
Try the lens on a different compatible camera and see if it works there. If it does, it could be that the lens you are using in incompatible with your camera. (Check your user manual for a list of compatible lenses)
However, if it does not work on the other camera as well, it could be that the lens itself is faulty, and would need to be serviced/repaired.
Since you say that other lenses work, I do not think its a fault with the camera, but either with the compatibility or circuitry of the lens in question.
Hope that helps!
  • 849 Answers
Do replace your camera battries because lense need more power to move. otherwise the two possibilities are there.
either zoom lense gear damaged or circuitry problem.
  • Cameras Master
  • 19,396 Answers
Try blowing canned air on the lens.
The camera is probably faulty.
Call the phone number listed on the owner manual, and get a quote for repair, or even better for a guaranty extension that will cover the repairs for one year.
    Sergeant:
  • 306 Answers
Wat brand ur camera is??
  • AbdulRahiman S Nov 18, 2008
    Maybe a long shot but make sure custom menu for the AE-L/AF-L button has not been set to option "5" ON. If it is the camera will only Autofcus via this button [ AE-L/AF-L].
    If you have done a camera reset it won`t be this.
    Master:
  • 763 Answers
Sir did you try to remove the batteries and see the settings on it? if all the possibilities didnt work on your camera then you must send it for repair service. they will open the case of your camera and fix the lens or maybe they will replace a new lens for that. if repairing this will cost you alot then you should buy a new one. if its under warranty then used it for your benefits.
thank you for using fixya
CHARCOIS
    Sergeant:
    Champion:
  • 347 Answers
Hello al39,
Do you mean everything is blurry or your camera can no longer zoom in and out?
  • Santiago Vallejo
    Santiago Vallejo Nov 18, 2008
    Algrey,
    could you pelase tell me the brand and model of your camera?
My Canon 7d will not longer autofocus using any of my lenses (I use TV mode). If I switch to AUTO the autofocus works and I hear the "beep, beep, beep." My lenses are all set to AF
Try cleaning the contacts on the lens mount and the lenses using an eraser. Do make sure that any dust falls outside and not into the body.
Jun 15, 2015 | Canon EOS 7D Digital Camera
Won't auto focus
Make sure the auto-manual focus switch on your camera is set to auto (A) and also make sure the auto manual focus selector on the lens is in auto (A) as well. If your lens contacts are dirty then this will affect the function of the lens as well. Clean those with either a lint free type cloth and alcohol or methylated spirits.
May 26, 2012 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I have the canon 50D and the 24-105mm L lens. Yesterday i took some images, and it worked fine. Today the auto focus is not working. When i press the button half way, nothing happens. If while i'm pressing...
This to me is a connection problem and may only require moving the AF-MF button back and forth a few times or removing the lens and cleaning the contacts between the lens and camera body.
Generally the "L" series lenses are pretty resilient in construction of offer the user few problems.
The lens contacts can be cleaned with a soft red rubber pencil eraser where you lightly polish the contact area of the gold contacts. Clean away any rubber dust with a lens cloth not a tissue, be extra careful not to get dust into the camera body cavity. reassemble the lens and try the camera lens operation
Diagram
This should clean up the problem
Jan 20, 2011 | Canon 24-105mm f/4L IS USM EF Lens
The lens no longer works on auto and as I wear glasses, I can't manually focus it.
Try cleaning the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Sep 20, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Error 99 and jerky fixation of focus between 17 and approxinately 30 mm works perfectly at zoom lengths beyond this with normal rapid fix of focus and records image normally. the error and failure to...
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
For the jerky focusing ring, you need to get the lens serviced by an authorized service center.
Aug 28, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Auto focus stopped working
Try cleaning the contacts on the camera and the lens, this is what usually prevents AF from working correctly.
Jul 26, 2010 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My lens quit auto focusing
It's probably broke then. Clean the contacts to the camera and try again. If it still don't work you can probably be sure it is likely to be a bit faulty. Check the camera has auto focus mode enabled if appropriate.
Jul 06, 2008 | Sigma 28-300mm f/3.5-6.3 Macro for Nikon-D...
AF problem with Quantaray 2X adapter
How does it stop working? Do you mean it doesn't auto focus anymore?
Many longer focal length lenses wont auto focus with 2x teleconverters on them.
Nov 27, 2007 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
