Question about Thermador RDF30 Dual Fuel (Electric and Gas) Kitchen Range
The display on the RDF30 Thermador cook oven shows an F-1 Code.
Not only does it show the F-1 Code but it beeps incessantly making sleeping next to impossible. Can you give me some immediate help at least to stop the ******* beeping.
  • lreuter Nov 18, 2008
    Referring me to another site does not help me. For the $9.99 fee, I thought what I would get is directions on how to stop the beeping.
    Again, the control panel on the Thermador RDF30 is showing an F1 code and continuously beeps...how do I stop it from beeping and get rid of the F1 code?
    Linda
    Sergeant:
    Champion:
  • 283 Answers
Unplug the oven for 15mins then plug it back. Reset the timer. Thank you..
Posted on Nov 18, 2008
  • amin dianalan
    amin dianalan Nov 18, 2008
    If still not working, try to contact service certer cause f1 code that shows on panel reponds for an error machine function.
    Brigadier General:
  • 6,966 Answers
To my knowledge, error code F1 is considered a fatal fault hence the incessant beeping sound to call the attention for immediate action. This would be the main logic controller of the unit, the brain.
Initially, you can try unplugging from the mains for an extended period. At the onset, the beeping may persist due to the residual electrical power internally.
Incidentally, was there anything out of the ordinary prior to the error code/beep: power interruption/outages, thunder storm, near lightning strike, electrical works done at the house?
Are you considering a DIY (do-it-yourself)? It requires familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Or perhaps your best bet would be to seek the services of a qualified professional or claim warranty repair.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Sergeant:
    Champion:
  • 347 Answers
Hello Linda,
The F1 error means "Internal logic failure (monitoring function). Sounds alarm and inhibits cook modes"
The way to repair it is to: "Replace the electronic range control (also called clock or ERC)"
If you dont have expereince at big apliances i recomend you to contact Thermador at:
http://www.thermador.com/about_us/contact.aspx
If you do know how to open up and replace the ERC, let me know and i will help you find one online.
Source: http://www.repairclinic.com/0078.asp#Thermador2
Good luck,
Dahaka
    Sergeant:
    Champion:
  • 251 Answers
Http://www.applianceaid.com go here to fix ur problem or this site http://www.pcappliancerepair.com/
  • Shaun Plencner
    Shaun Plencner Nov 18, 2008
    F1
    F2
    Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions
    Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
    F3
    Open circuit detected; oven temperature sensor. Check sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check wires and connections between electronic range control (also called clock or ERC) and oven temperature sensor
    Replace sensor if other components check normal. Replace electronic range control (also called clock or ERC) if fail code reoccurs
    F4
    Short circuit detected; oven temperature sensor. Check sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check wires between electronic range control (also called clock or ERC) and sensor.
    F7
    Function key shorted for over 16 seconds. Check for something pressing a key or preventing normal release of the key
    Replace electronic range control (also called clock or ERC) if other components check normal
    F8
    Internal logic failure; calibration. Alarm sounds and resets to non-cook mode. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 F). Check wires and connections between electronic range control (also called clock or ERC) and oven temperature sensor
    Replace electronic range control (also called clock or ERC) and oven temperature sensor if other components check normal
    F9
    Internal logic failure; door latch supervision. Alarm sounds and resets to non-cook mode. If door is locked due to clean temperatures, disconnect power until door can be unlocked
    Fd
    Bake & Broil relay drives active simultaneously. Check relay board for damage: trace E6 to K2 & K3, and burned contacts K3 & K4
    Replace electronic range control (also called clock or ERC). Replace relay board if necessary
    Blank display
    No power to electronic range control (also called clock or ERC). Check oven light and cooktop dial lights (powered by L2 & L1, respectively). Check relay board transformer primary, E1 to E2 (140 ohms typical). If the transformer internal fuse is still OK, check output voltages, pins 9 - 8 (3.2 v.a.c.) and 7 - 6 (21 v.a.c.). Check clock functions after replacing relay board
    If relay board transformer open (E1 to E2), replace relay board. If still no clock functions replace electronic range control (also called clock or ERC)
    HERE ARE THE TROUBLE CODE FOR UR OVEN
  • Shaun Plencner
    please look at my other comment with the trouble codes for ur oven
    Here to help
    Shaun
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
I have " E
E1 - Control board problem
Notes: C, E
C:
Disables clean mode in Thermador device, allows cook and microwave
E:
1. Turn the clock selector knob to OFF
2. "Tweak" the oven control by turning the clock selector knob slightly to the left
(counter clockwise).
This may stop the flashing message/beeping and clear the display window.
Hope helps.
Jul 24, 2011 | Thermador T18BF70FSE Freezer
Thermador prd486edg oven/heating flashing 1/2and neither oven heats. help!
only code that is close ( e12) ( E12) look at display and make sure .. mm if the code is E12 then " CT oven:latch switch problem ) this may help Note E . 1 turn the clock selector knob to off 2 tweak the oven control by turning the clock selector slightly to the left ( counter clockwise ) this may stop the flashig message / beeping and clear the display window. " try it and pray mm .
Dec 09, 2009 | Thermador PG304BS Gas Kitchen Range
F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Nov 09, 2008 | Thermador SC272T Electric Double Oven
Oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Oct 19, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Thermador 30" Dual-Fuel Range 0FF error
Make sure there is proper electrical power going to range. Then check your kitcen circuit breakers or fuse box in your house, then reset the oven controls.
LOL look what i found, a CHILD LOCKOUT FUNCTION-- check this out
TO SET CHILD LOCKOUT
Press and hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF appears in the
display (approximately 6 seconds).
TO CANCEL THE CHILD LOCKOUT
Press and Hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF disappears
from the display (approximately 6 seconds). Mode selections will now be available on the control panel.
looks like someones could have been playing with the buttons and locked you out..
Let me know what happen.........................please rate this
Oct 15, 2008 | Thermador RDF30 Dual Fuel (Electric and...
I am quoting above because I really need help. "When I push any of the function buttons on the oven console (Timer, Bake, Broil, Clock) the display shows 0FF in red next to the clock. The oven will not turn on and the timer will not work. I can not find any troubleshooting information on this problem. The oven is a model RDDS30V. Any help would be greatly appreciated!"
Apr 17, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Thermador sm272zs microwave/oven combo
Woke up this morning and heard my smw272 built-in oven beeping. Oh no! First the display (but at least the oven worked) now the oven is beeping (fault signal according to manual) and the thing is dead except for the microwave and warming bin. The only way to turn off the incessant beeping--which was driving me crazy--was to go outside to the fuse box and turn off the circuit to the oven. Yeah, I stopped the beeping but now I'm at the mercy of the unscrupulous service repairman--was quoted a flat fee to drive out and a hefty hourly rate (i.e., "value added" service charge). OUCH! Hey folks, please follow my simple advice if you want to avoid making a big mistake: NO MORE THERMADORS. RUN--DON'T WALK AWAY FROM THIS BRAND!!!
Pruneau
Aug 18, 2007 | Thermador SMW272 Electric Double Oven
Thermador RDF30 Dual Fuel (Electric and Gas) Kitchen Range Logo
314 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
