SOURCE: LVM-37w1 Replacement Stand
The stand for this model is not available complete. Please contact Eddie for more info @ (562) 236-9800 x128.
SOURCE: L37W1
I did take a few photos but just to help me get the connectors and covers back into place. I deleted them soon after but I would suggest this prior to removing them as they are tiny, etc. but you already know this. My TV has never had that problem again and I am very proud to have fixed it. It easily saved me a $450 repair bill, or worse, I new 37-inch at over $1000 I am sure for a 1080p.
SOURCE: LVM-37w1 Westinghouse
If you getting a lot of vertical lines, double picture, it can be the LCD panel driver board, or worst case will be the LCD panel, very expensive.
SOURCE: I have the westinghouse monitor ( modeL #
Hello, this model has two ribon cables that run from the t_con board to the panel, it sounds like you might have to replace one of them if not the whole t_con board. You can find parts for this at www.shopjimmy.com, I would recommend you taking this unit to a certified repair center if you are not atleast a bit technical because you have to did a bit deep in to the set for this one.
SOURCE: Westinghouse LVM 37w1 Screen goes
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
