Question about O2 Xda IIs Pocket PC
No internet how can i connect 2 internet
    Sniper:
  • 73 Answers
Go to somewhere with wifi
Posted on Aug 25, 2009
How to connect bsnl postpaid gprs from samsung SGH-D780 mobile as modem. i have alreeady downloaded settings from the network operator.
If you want to use a USB cable connection, you must first install Microsoft ActiveSync version 4.2 or later on the computer.
Before using Internet Sharing, disable ActiveSync on your computer.
To set up your device as a USB modem
1. On your device, tap Start > Programs > Internet Sharing.
2. In the PC Connection list, select USB.
3. In the Network Connection list, select the name of the connection that your device uses to connect to the Internet.
4. Plug in the USB cable between your device and the computer.
5. Tap Connect.
To end the Internet connection
On the Internet Sharing screen, tap Disconnect.
Sep 17, 2010 | HTC P3300 Smartphone
1.how to connect to internet network. 2. how to
1.To connect to internet through your mobile corby, you need to install PC suite and need to subscribe to packet data.
You can download the PC suite from below website
http://www.samsung.com/us/support/download/supportGlobalDownloadPrdDetail.do
In this website please select the following from the dropdown list,
1.Product type
2.Product sub type
3.Model number
After selecting the model it shows the PC suite for your mobile model.Download it and install in your computer.
2.To subscribe to packet data you need to contact your service provider through phone or go directly to their office.
They will send you the settings for your model. Please save the settings to your phone and set it has a default settings.Then you can start using the internet in your phone.
After doing this two you can connect to the internet using mobile as modem.
3.To get the manual go to manual tag and you can download the manual.
Thank You
Aug 17, 2010 | Samsung Blackjack SGH-I607 Smartphone
Web opening problem
The windows based phones usually O2 requires generation 2 internet connection. So you check with your service provider for the connection type.
If it is 2nd generation internet connection then check the GPRS settings in Settings>Connection for the authentication. If PAP is selected then try with CHAP, because it varies based on the service provider.
Aug 06, 2009 | O2 Xda Atom Exec Smartphone
Connecting internet through tytn II
You need to install Activesync on your Laptop.
Then connect the device via USB. Once connected open the Comm manager, then you can select "Internet Sharing"
Select USB, and the network connection you want to use, then hit the connect button. You should see the laptop pick up and get an IP from the new connection.
Then you will be connected via your active network connection from the phone :)
Jun 16, 2009 | HTC TyTN Smartphone
What to do for gprs activation in nokia 9300
hi,
1. Go to Tools > Control panel > Connections > Internet setup.
2. Select the tab Connections and Select New.
3. The question "Do you want to create a copy of existing Internet access point?" appears; Press No.
4. Choose Next.
5. Enter a name for the connection, for example internet.
6. Set Network-ID to Internet.
7. Set Internet settings type to GPRS.
8. Press Next.
9. Fill in access point name (APN).
10. Leave Username and password blank.
11. Press Next and Finish.
After setting up your phone continue with step 2
Apr 14, 2009 | Nokia 9300 Handheld
Phw acess gprs on htc p3400i
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Dec 20, 2008 | HTC Touch P3450 Smartphone
Htc p3400 airtel gprs enabled not connecting internet with p.c.
Its not true that one cannot access internet on pc via htc p3400i. Right now I am using the same to post this message. The problem is there is not much help available on the internet. Hence i have decided to post the solution.
Here are the steps.I took to enable vodafone mobile connect on my htc p3400.
1) You will first have to enable gprs on you mobile by calling helpline. 2) Go to start->settings->connections(tab)->connections     Click advanced tab. Then cilck select networks. You will see 2 drop downs. In first drop down select vodafone mobile connect and in second drop down select my isp.     This is all that you need to configure on the phone.
   Now connect the data cable to the pc and then connect the phone to the cable. you will be asked two questions. Select USB for one and select vodafone mobile connect for the second.
   Now go to start->programs->internet sharing and say connect. You are now ready to surf internet on the pc. just fire your fav browser and check it out.
Thanks, Nilesh Gadkari
Nov 23, 2008 | HTC Touch P3450 Smartphone
INTERNET SETTIN
on your i-mate JAQ go to programs>internet sharing>connect.
prior to this pl make sure that your pda is connected to ur desktop via USB cable and it is synked with the desktop.
rgds,
May 10, 2008 | i-mate JAQ Pocket PC
Internet
hi i am sabbirmobile frome india,
will you go inside of mobile manu(1)click windaws start boton and go in sating(2)click on connection(3)add new connection(4)write your internet seting name(5)write your internet provider name(6)type ip addres(7)type proxy addres and click ok.
now enjoy your internet connection.
Jan 24, 2008 | HP iPAQ hw6515 Pocket PC
How to connect to internet
You have two possibilities to connect your PDA to internet. First one is to use connection of your PC or Notebook. Check please connection settings under Start>Settings>Connections. If you want to make automatically connection to Internet, use first option. Under “Modify” you have possibility to create new connection. Did you already try to make connection like this? Look on http://www.microsoft.com/windowsmobile/help/pocketpc/ossupport.aspx There you can find lots of useful information how to connect PDA to Internet. If you want to make connection using Bluetooth, look at https://eu.computers.toshiba-europe.com . There you can find Bluetooth SD Card 2 which you need for Bluetooth connection.
Sep 11, 2005 | Toshiba e350 Pocket PC
O2 Xda IIs Pocket PC Logo
139 people viewed this question
Top O2 Computers & Internet Experts
Rob
Rob
Level 1 Expert
xxxxxx xxx
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
