BOTH TRIPS WEAR IT DIED IT WAS REALLY ROUGH WOULD WATER GETTING IN TO MOTOR MAKE THIS HAPPEN
SOURCE: Starts fine when cold, after running dies on idle then wont start
Sounds like the fuel filter is dirty and needing to be changed. It's cheap and easy to swap out.
SOURCE: 1985 Corvette, starts runs rough then dies
I have a 85 coupe,the pumps are notorous for going out.Best bet is empty the whole tank.the pump .Is easy to pull its under the filler door.1 make sure its not your security system shutting off
your injectors .2 turn key in on poss and open gas door you should hear the motor.If not
disconnect batt and remove.be car e you dont lose the screen.once out dry off and hook up to any batt to check.there only 30 bucks but make sure you ground it out right and dont turn it on in a dry tank ,you will burn it out.
SOURCE: 2000 VW Beetle dies occasionally and won't start for a while
run a scan tool on it and make sure there are no codes, if there is codes address those problems first, if no codes.. next time it won't start check for fuel preasure. it is probably a fuel pump getting ready to go out or they may be a large amount of something other than gas clogging the pick-up sock at bottom of fuel pump.
SOURCE: engine dies, starts rough
Most large parts stores read codes free. Most common cause is crank sensor, but I'd have code checked before buying anything.
