Question about Baby Lock Ellure
Babylock ellure plus embroidery machine, error message
Error message is "the safety device has been activated" and the user manual tells me that the thread is tangled, this is not the case. The sewing machine will not start and will not embroider.
Any help you can give is appreciated
  • 323 Answers
SOURCE: Brother 2001 sewing and embroidery machine.
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
sewman7
Posted on Jun 18, 2008
  • 4 Answers
SOURCE: Baby Lock Ellure
I HAVE HAD THIS HAPPEN SEVERAL TIMES AND WHEN I WOULD CHECK THREAD IT WOULD BE OK, MOST OF THE TIME HOWEVER, IF I COMPLETELY UNTHREAD IT AND RETHREAD IT THE PROBLEM IS SOLVED. I HATE IT WHEN THEY DO THIS MUST BE A PROBLEM WITH ALL OF THEM
Posted on Aug 12, 2008
SOURCE: Babylock ellure safety device
I have the same problem, I have done what the book says but no luck yet. Have you figured out what happened? And do the experts really check the questions? Cause I asked a question awhile ago, and no answers. Help!
Posted on Oct 14, 2008
dupina
  • 110 Answers
SOURCE: A brand new Singer Quantum
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Posted on Dec 08, 2008
SOURCE: my ellure machine has got
I have 1994 airostar van 4.0 spark knocks on regular gas also scaned sead had slow injector puls
Posted on Jan 02, 2009
Babylock frozen tight its a eklure plus only used 6 time I've check bobbin cade changed needle although it was fine shut it off and turn it on. Bobbin winder on right side. It threw up a safety warning...
Sounds like it's time for a visit to the repair shop Babylock Ellure
is a fairly nice machine, it will be worth it...
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 23, 2014 | Sewing Machines
Hi! I am planning to buy a babylock machine. iread about, but I still don,t know what to buy between Sofia 2 and Ellure Plus.
Looking at the babylock.com website the Ellure Plus has more stitches although they are both machine embroidery machines. The Ellure Plus has a larger embroidery field than the Sofia though so this may well clinch it, 4" x 4" versus 5" x 7", I know I would go for the larger embroidery field so I didn't need to reset the hoop.
I guess though it comes down to price and will you use all the extra features of the Ellure Plus. If you are mainly doing clothing and home dec then you really don't need the embroidery features at all, its a personal preference though.
Have you been in for a demonstration and used both machines yourself? Sometimes the little things will crystilise the decision for you. Look at ease of threading up, lighting in the sewing area, size of the free arm and how easy it is to program and set up the embroidery functions. Then decide if the extra cost is worth it, sometimes its better to spend more now and not outgrow the machine's functions, but you know what your sewing needs are so its something you have to weigh up.
Sep 13, 2011 | Baby Lock Ellure
My babylock ellure won't work on the embroidery mode, but works on the sewing mode. I only use this machine for embroidery. When I turn it on it tells me to lift the pressor foot, which I do, but nothing...
Ours did the same thing. They said it was the circuit board for embroidery that went bad. The one for sewing is still good. They wanted $200 to $300 to replace it.
Oct 19, 2010 | Baby Lock Ellure
Can the babylock Ellure be upgraded to USB?
You could do worse than ask a Babylock dealer or their general contact, both available HERE
Sep 10, 2009 | Baby Lock Ellure
Baby Lock Embroidery Sewing Machine "ELLURE" Model ESL- Problem: Defective Embroidery Memory Card (part#35205-4) used with the "PTS BOX" and the Palette Ver 1.0 Software Program to transfer embroidery...
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
Jul 11, 2009 | Baby Lock Ellure
Baby lock Ellegante 2 embroidery machine
try and look here
http://www.babylock.com/embroidery/ellegante/
there is a help section
Jan 11, 2009 | Baby Lock Ellure
Babylock Ellure Embroidery Unit Malfunction
You need to make sure that the embroidery arm is able to move freely be sure that it has no obstructions like a wall behind your sewing table or fabric that may be stacked nearby. If all is clear you probably have thread wrapped somewhere inside the embroidery unit it only take a little bit to jam up the works. You can try to take off the cover by flipping the unit over and removing the screws to the embroidery arm. I would take it to the shop where you bought it they should be able to help you for free if it is new. If you have the original packaging you can send the machine to Steve's at www.stevessewandvac.com just send them an email they can help.
Jul 27, 2008 | Baby Lock Ellure
Embroidery downloads baby lock ellure plus
If not a USB model, you have to get the disgustingly expensive Babylock palette box ($500) and software with the blank card to transfer the designs from cd or files. Beware of making the embroidery too small, it can make the stitch density too great and then the machine cannot sew the design. There is software called Density Works to deal with this problem.
Apr 04, 2008 | Baby Lock Ellure
Mar 22, 2008 | Baby Lock Ellure
Sewing Machines Logo
369 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
