Question about Aiptek ISDV2.4 Flash Media Camcorder
Shutter button doesn't pop back up
Camera = Aiptek ISDV2.4
The shutter button on top is suppressed and will not pop back up (no play in the button anymore). I took the screws out and looked inside. All I found was a long grey tab. I'm not sure what it attaches to or what it is supposed to come in contact with to take a picture. I did not find a loose spring inside either.
I wanted to see an exploded view of the inside of the video camera, but cannot find one.
If someone would please respond by Friday, Nov 21st, that would be great!
Thanks in advance for your help.
  • 21 Answers
SOURCE: Wont read sd card..screen shows card locked..card ok
Aiptek is not so good at answering emails. If Nitrotrike's suggestion doesn't work, try posting this question at
http://forums.steves-digicams.com/forums/view_forum.php?id=92
Those guys are more likely to help you (or at least try) more quickly than Aiptek.
Posted on Jan 19, 2008
  • 37 Answers
SOURCE: aiptek - Video and sound is out of sync
In order to play hi def movies without upgrading anything on your PC, download Quicktime for windows, It supports hi-def video, and the PRO version ($20) lets you change the format without quality loss.
Posted on Sep 26, 2008
  • 3 Answers
SOURCE: AIPTEK PROBLEMS
Do what I do- take out the SD card and transfer files directly to the computer without the camera.
Posted on Nov 09, 2008
tostitosmith
  • 11 Answers
SOURCE: I have an aiptek DZO-V3T camera.I got vidio and
Hey try plugging in the cord to the USB Prt on the Hard-Drive, if you are plugging it into the Monitor or vice-versa. I have the same camera, and I plug it into the monitor. If all else fails, take out the memory card and put it into a digital camera, or something like that and connect the camera.
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: My camera's monitor/screen is black with no picture
My AIPTEK 1080p was powering on but the screen was turning off within one second of turning the unit on. I verified that the camera was still working and just the output onto the screen failed. I was able to resolve this by hooking the camcorder up to the TV and viewing the menus on the TV and then turning the camcorder off with the power button. I think this problem happened because I didn't do a "clean" shutdown the last time I had my aiptek hooked up to the TV. It is now working perfectly!
Posted on Jan 17, 2010
My Nikon L35 AF's shutter button won't pop back up when I press it down.
Hi Broderick,
You have some (dirt/ dust/ sand) clogged around the clearance between the shutter button and the camera body. If you are a DIY type of person, you can check and clean that dirt, other wise take it to a repair shop for proper cleaning.
Jan 14, 2016 | Nikon Cameras
Frozen shutter
The usual cause of this is a failure of the motor in the SQ unit that drives the mirror up and down, operates the aperture lever, and charges the shutter. This parts is so notoriously bad that it is on permanent back order at Nikon
Some of the other solutions with popped shutter blades - usually when I see this it is caused by the customer trying to clean his image sensor and having the shutter blades close on his/her tool.
Jan 17, 2012 | Nikon D40x Digital Camera
My 645 1000s shutter buttons wont pop back up.this is my 1st mamiya
You might want to check and make sure the battery is still good. If you purchased the camera used and didn't change the battery then this might be the case.
But in the mean time this is what you need to do:
1st-make sure that the shutter speed dial is set to any shutter speed other than the red circle w/red ring. If your camera is set to that it will drain your battery when not in use since it is designed to be an automatic setting. I set mine to 1/125th to do this push in the circular dial on the side and at the same time turn the knob.
2nd- locate the 2 levers on the opposite side of the shutter speed dial. Once you found them then position the back lever all the way forward towards the setting for "MULTI" and position the lever towards the front straight up.
3rd- then wind the film crank till it won't wind anymore and depress the shutter, if it is wound and the shutter release is still stuck then skip to the fourth step, if something happened and you heard a click then still proceed to the next step because no the shutter release will be temporarily stuck.
4th-Once both of these levers are in this position there should be a red button just behind the shutter release button on the top right side of the camera.... drum roll please...."Push the red button" what you should hear is a rather loud click, this click is the mirror releasing allowing you to: 1 wind the film crank and take another picture and 2 this also now allows you to see through the lens again (assuming that you have a lens on the camera).
In Conclusion: without a battery that is fully functional in the camera this is how the camera will operate once you get a battery for your camera then reposition the levers on the side of the camera opposite of what I suggested (this will be the normal operating mode for the camera with a battery) then when you wind the film crank and depress the shutter everything will function normally.
Jul 12, 2011 | Mamiya Photography
Shutter button popped off
If you do a search for "sony h2 shutter button replacement" on Google.com you will find a shop that sells both the shutter button and a repair service to install the shutter as well.
Hope this helps!
Jul 06, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Shutter release
take it back to the shop
Aug 06, 2008 | Pentax *ist DS Digital Camera
Flash
Your camera is set at twilnight mode which has the flash suppressed and you won't be able to turn it on because of the fixed setting of twilnight mode to get the proper result of the picture. Due to the mode setting requirement, a shakey hand icon and no flash icon will show. If you press the flash mode button, it beeps. The twilnight setting has a low shutter speed, i.e. the shutter opens longer to allow more lights in, therefore it shows recording to let you know that the shutter is still open, and any moment of the camera will result in a blurred picture.
Now, check your camera mode dial and turn it back to the 'green' camera and see if you can get the flash to fire.
Jul 08, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Faulty nikon d40
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
Rob Smith
Victoria, BC
Nov 01, 2007 | Nikon D40x Digital Camera
Failed shutter release
If you decide to open your camera, here's a pictorial disassembly. Don't go any further than popping the top off to examine components in the vicinity of the shutter button. Look for anyhting different than what's showing in the picture. Remember that you can be creative with a little bit of glue, and a small piece of scrap plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
And keep in mind there's a potential for electrical shock. Read this first before you turn any screws:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Oct 02, 2007 | Canon PowerShot A95 Digital Camera
A flash problem
there could be a few reasons for that: 1. The Mode Dial has been moved to another setting - Set the Mode dial to the correct setting. 2. The flash is set to Suppressed Flash mode - Set the flash to Auto, Red-eye Reduction or Forced Flash mode. 3. You pressed the shutter button while the flash was charging - Wait until charging is complete before pressing the shutter button.
Sep 15, 2005 | Toshiba PDR-M3 Digital Camera
Open Questions:
Aiptek ISDV2.4 Flash Media Camcorder Logo
51 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
Michael Galve
Michael Galve
Jose Ma DM.
Jose Ma DM.
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
