Question about Amana ARB1905C Bottom Freezer Refrigerator
Ice Dispenser Problem - Runs for no reason
Recently the ice dispenser on my Amana side by side refrigerator started acting funny. The ice dispenser will continually run, even though we are not activating the dispenser from the door. I've had to remove the tray from inside to prevent ice from falling out of the fridge during the day and night. The motor for the dispenser still comes on at random times for no reason that I can tell. It is almost as if the switch has a short or is semi-stuck in the on position, thus causing the motor to engage. Also, if I open the freezer door, there is a switch at the top of the door frame and if I depress that switch, the motor is engaged. I don't see anything wrong with the switch, but that doesn't mean that's the case. Any advice here would be greatly appreciated.
    President:
  • 878 Answers
I think your problem is in the dispenser lever switch or the lever itself. Don't worry about the upper door switch, it's the dispenser switch that's sending power to the auger motor. I would give you a part number but the posted model number is for a bottom freezer model. Catriver..
Posted on Dec 06, 2006
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Frozen food defrosted and ice maker stopped working......water dispenser is working and refrigerator is working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
adafd
Apr 11, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker will not make ice, water dispenser is working
heatman101
oypyiooiyp
May 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Frost build up around ice dispenser in freezer
Suddenly having the same problem. Any solution?
May 16, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Amana Refridgerator Freezer, French Doors
Most side-by-sides have a length of hose at the bottom of the freezer that send the water to the ice maker and water dispenser. take the back off so you can see this hose, there may be a kink in it, or a clog.
May 30, 2008 | Amana ACD2232HR Side by Side Refrigerator
Ice dispenser not working
Ice auger in freezer compartment not working. Common problem with GE side by sides I know of at least 3
Jan 21, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana side by side ice dispenser leaking water
Take the ice maker out and look at the mold. If the coating is flaking off then that is where it is leaking. Will need to replace the ice maker.
Sep 29, 2007 | Refrigerators
Amana ARB1905C Bottom Freezer Refrigerator Logo
129 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
