Question about Hotpoint RB757 Electric Kitchen Range
Oven not heating
I replaced the bake element which didn't correct the problem. Could it be a fuse? The oven stopped working after an ice storm.
  • 962 Answers
It may have a reset somewhere along thecircuit.
Posted on Nov 18, 2008
Why won't the lower element heat?
DID U TEST THE NEW ELEMENT B4 TRYING IT? U MIGHT BE SURPRISE. OTHER WISE I WOULD D SAY CHECK THE WIRING AND CONNECTIONS IF ITS NOT WORKING, CHECK FOR VOLTAGE AT THE CONNECTORS?
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Jun 25, 2015 | Ovens
Oven elements aren't heating, Kenmore Range C970-655821
THINGS TO CHECK:
the broil element
The bake element
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 22, 2015 | Kenmore Ovens
I have a Samsung electric range FTQ352IWUX, and neither oven functions (bake nor broil) produce any heat.
THINGS TO CHECK:
the broil element
The bake element
Apr 18, 2015 | Samsung Ovens
Oven not working everything else works fine
THINGS TO CHECK:
the broil element
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 13, 2015 | Ovens
I have a tricity benfix electric oven.. My main oven and top oven have both stopped working, but my hob and grill work fine, how do I fix my ovens? What the problem?
THINGS TO CHECK:
the broil element
The bake element
Mar 20, 2015 | Ovens
Oven
THINGS TO CHECK:
the broil element
The bake element
Apr 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Eloectric Oven wont heat up either element.
THINGS TO CHECK:
the broil element
The bake element
Feb 06, 2014 | Frigidaire Bake Element 316075103
Oven elements don't heat up.
the broil element
The bake element
Belling synergie main oven not heating
THINGS TO CHECK:
the broil element
The bake element
Feb 06, 2014 | Belling XOU174 Electric Single Oven
My 30" wall oven oven won't heat up. the clock works and it allows me to put in bake, 350 degrees, but the elements don't heat up. we had a storm and the power flickered on and off several times. is there...
There is a safety thermostat (thermal fuse) on the back wall of the oven that interrupts power from L1 to the Bake and Broil elements. This fails open on an over-temperature or over-current condition. The oven needs to come out of the wall to replace it - best left to a tech unless you are experienced in such things.
Best Regards,
Bruce
www.fixyourboard.com
Jun 21, 2010 | Frigidaire 30 in. Electric Gallery Series...
Hotpoint RB757 Electric Kitchen Range Logo
96 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
