Question about Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver
Saeco talea ring coffee machine reurning error code
Hi There, we have a Talea ring returning error code 1, can you tell me what this error code means and if I can resolve myself or need to return to a service centre?
  • 2 more comments
  • desertcobra
    desertcobra Dec 05, 2008
    Can You please tell me what is error 5? Its displayed as soon as i turn button on.
    Thanks in advance
  • Martin No Feb 17, 2009
    Error code 1. HMMM
    Can I fix it myself by cleaning the grinder of should I send it to service?
  • gyongyichend
    gyongyichend Feb 10, 2013
    I got error 3 code. What means? How can I solve this? Thanks!
  • gyongyichend
    I got code error 3. How can I solve this? Thanks!
Thanks Johnny,
the machine wont make coffee at all as it stands. Justn returns code 1 as soon as you push the button for coffee. Is the sensor optical or a microswitch? Can you tell me where the sensor is located so that we can have a go at cleaning it?
Posted on Nov 18, 2008
  • 1 more comment
  • Love to fix Jul 17, 2011
    I just took out my grinder and cleaned it due to error code 1. I removed it with instruction from another post in Fix-ya. It was tricky getting the cover off and really pops off. The sensor is magnetic and on the bottom gear of the grinder are two little magnets on opposite sides of the gear wheel. I discovered after reassembly that the magnet has to be aligned up with the sensor for the grinder to startup. If Clogged, there probably is too much friction which throws the alignment off. I suppose you could try to turn the grinder to coarse and then use a 10mm socket to turn the grinder in increments to find startup position again and then try to use an allen key to reach down the pre-ground feed hole and clear out the grinder outlet. Beware there is a metal flap that is in there at a 45 degree angle that acts as a baffle that you will need to reach under. try using a dental mirror. Personally' I'm glad I took my grinder out as I know how to do it now and was able to clean it better. Note that the grinder seems to be a one piece design after the motor is removed. I think if you use oily beans it's not as matter of if error code 1 will happen it is when. I've had my unit for 1.5 years.
  • peter_ngu727
    peter_ngu727 Sep 08, 2012
    Lucan you tell me where the instructions are on fixya to disassemble the grinder? Thx
  • peter_ngu727
    Can you tell me where you found the instructions to clean the grinder on fixya? Thanks!
  • Saeco Expert
  • 223 Answers
Code error 1 on talea modes means that your grinder is blocked and grinder sensor is not reading properly.
Are you using oily beans? If you are using oily beans the oils may be blocking the grinder and giving the code 1, and you should try to switch to non oily beans before getting it serviced.
We are authorized Saeco Talea repair center based out of New York. You can if our contact info at
If you need a service center near you visit
Saeco talea grinder is starting when you start the machine
this sounds like the machine simply needs a good cleaning due to grounds jamming the switch in place
Sep 05, 2014 | Saeco Talea Ring Plus Espresso Maker with...
On my talea ring plus i get an error code 5. anybody knows what that is?
Error 5 is the water circuit is block, or airlock in the system that means you have to purge the air out.
Feb 11, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Out of service [4] out of service [87] restart to solve the problem SAECO TALEA RING PLUS
Hi...itis not self otherword the motor in the gearbox is not working, either itis jammed with rust cuz' of leakage or motor is bad.
Dec 04, 2009 | Saeco Talea Giro Espresso Machine
Saeco Talea Ring Plus: often, water flows out of of water steam
The valve parts need to be replaced, if it is only happening when brewing coffee then there is so much pressure on the pump that it is forcing the valve open. First try adjusting the amount of coffee be added to the chamber for brewing.
Aug 23, 2009 | Coffee Makers & Espresso Machines
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
The French Saeco website has manuals (in English as well as French).
Try this url…
Mar 16, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Talea Touch - Drip Tray not raising/lowering smoothly
It can be the sensor or the engine that have to be replaced:-(
Best regards
Sep 08, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver Logo
2,015 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
