FixYa.com
Tags:
Acer Veriton 5100 PC Desktop
Help
posted by biljana on Dec 06, 2006
Hi
When I start my computer,safe mode is on all the time.I've restarted the computer thousands times and is the same. Even though I do not understand problems I found that something is wrong with "PCI Ethernet controller".Can you, please, tell me some solution for this problem?
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 30, 2007
FixYa! (100)
locateroy
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
If you are still having troubles, try this.
Click on start> run> type in msconfig> ok>
click on the boot.ini tab> make sure the safeboot box is not checked.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 06, 2006
FixYa! (100)
Swobovike
Rank:Master Master
Rating: 81%, 149 votes
With most computers there is a black screen with a countdown timer that will select the last known configuration unless you choose something else. This is part of the Bios, I believe. When booting the computer you should see a countdown timer with one of a couple of options for booting. Choose a normal boot and see if that works. If you do not see this countdown timer screen when powering up then you may have to make changes to your Bios (select F8 when booting to get to the Bios menu) so that there is a delay before booting to OS.
Just a thought. I agree with the other solution that it is likely the ethernet card does not work because those drivers are not NORMALLY loaded in Safe Mode.
Solution #3
FixYa! (100)
sandrew
Rank:Wiz Wiz
Rating: 83%, 4487 votes
If the System restore, does not work, you may have your pc set to safeboot or safe mode.
This would be the reasopn why your ethernet card controller is not working as non of the required graphics or pci drivers will load in safe mode.
Check by Start>run, then type 'msconfig' and look at the 'General Tab' and make sure normal or selective boot up radio button is ticked and not the diagnostic start up.
Also go to 'Boot.INI' tab and make sure 'Safeboot' is not ticked.
Click apply and restart pc.
Solution #4
Helpful (85)
vijay
Rank:Master Master
Rating: 82%, 57 votes
Please remove the pci ethernet controller and restart the pc. If you are using windows xp go to safe mode by pressing f8 and do the following
start -> programmer -> accessories -> system tools -> system restore.
once the restore starts choose a date you fell your pc worked well and continue. Thats all your sytem restores to that date and try reistalling the pci ethernet cord with suitable drivers.
give me feed back
Solution #5
posted on Jan 24, 2007
Not Rated (0)
john15
Rating: 0%, 0 votes
just type msconfig in run window and from there select bootup normally,it won't go to safemode again
start-run-msconfig-boot normally
This Problem Also Relates To: HP Compaq dc7600 PC Desktop HP Pavilion a1240n (EG136AA) PC Desktop HP HP Compaq Business Desktop dx2200 - P4 524 3.06 GHz (S6104464) HP HP PAVILION A6230N DESKTOP PC HP Pavilion a1200y (EK457AV) PC Desktop HP Compaq Business d530 Ultra-Slim PC Desktop HP Compaq dx2000 Microtower PC Desktop
Can you Help with these PC Desktops problems?
PC Desktops
how do i use my
how do i use my netopia usb... Answer This...
PC Desktops
Hello, I am trying to create
Hello, I am trying to create... Answer This...
PC Desktops
I can't get my mail
I can't get my mail to come up. Answer This...
PC Desktops
i'm trying to set up
i'm trying to set up my linksys... Answer This...
PC buzzing, then stops...
Hello, I bought this acer M5100... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
