Question about Zenith C27A24T 27" TV
Converter box worked fine and now wont get any signal
I hooked up my converter box and got perfect reception, I watched tv for a few hours and then went to bed. When I woke up the next day i couldnt get any signal. I've now replaced the box twice, and both of my antennas, and still no signal. Any ideas?
Did you go through the complete setup by putting your TV on Channel 3 and letting it scan all of your channels or are you just hooking up the box and not doing this? Make sure the box is set to "blue" which is On and do the complete setup.
Posted on Dec 01, 2008
No tv reception
Ur tv is analog tv u know that right?U have pay cable or other pay tv services hook up to ur tv?All CRT are analog tvs and no longer able to recieve free air tv signal reception without the converter box.It all digital now,analog,CRT tvs to get DTV must have a converter box.
Apr 11, 2010 | Sansui 27" TV
We recently purchase 2 TB1 10MW9 DTV Digital Analog Converters to connect to 2 of our Ananlog TV's. Our TV reception is from Comcast Cable & we had then set-up our Main TV with their converter. Our...
U have paid cable, u don't need the converter box.Not even the analog tv require the coverter box, if u have paid cable or satalite tv or telicom signal.All ur tvs is hook up to the Comcast Cable correct?That all u need not, require the converter box.
Sep 03, 2009 | Televison & Video
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Oct 10, 2008 | Zenith C27A24T 27" TV
INTERMITTENT RECEPTION WITH INSIGNIA
I suggest that you swap a one of the better boxes with the one that is not so good. If you get the same condition there is nothing wrong with the converters. You probably have a signal loss on the one that is not like the other two, could be a poor connection, wrong type of coax, defective splitter or many other things. Good luck!
Jun 15, 2008 | Insignia Digital-to-Analog Converter for...
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Zenith C27A24T 27" TV Logo
104 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
