Question about Curtis RCD856 CD Shelf System
Strange niose when i try to turn it on
When i try to turn on my stereo the diplay turns on and off but while this is hapeneing a click/beeping niose is hapening at the same that it is turning on and off. at first i thought it might have something to do with the lighting in the room interfering with the remote sensor. but it doesnt just happen sometimes it happens all the time, even at night. thanks for reading. hope you can help.
    President:
  • 3,130 Answers
There is a short in the amp. circuit, and it is shutting on and off the power supply circuit in the unit. Most likely you have bad output devices in this unit. Most of the time, im sorry to say, it is not worth the cost to repair the output devices, as A new unit would be about the same if not more. The only real way to tell, would be to invest in an estimate. Good Luck
Posted on Dec 28, 2006
No beep no display
did you check out the power supply out are all the power cables in? is the switch on the power supply turn on some do have them on the back of supply ok.
Nov 28, 2013 | Foxconn Computers & Internet
Car stereo not working,, could be in safe mode ?
Sorry to tell you this needs to have the code reset once you remove the battery the stereo needs to be reset only a garage can do that there is no doubt about it. Hope this helps Best wishes, Malcolm Campbell.
May 09, 2017 | Vauxhall Cars & Trucks
Strange clicking noise OKI C5600
it is not the toner it is the drum. just replace the drum and it will be fine. you may of noticed your printer has been printing a little streaky. i have had this problem with my c5600 and after i replaced the k drum (the noisy drum) it was fixed intill 4 months later when the blasted thing broke again
Jun 02, 2010 | OKI C5400 Laser Printer
My screen went black while watching tv a fuse or somthing else?
If your TV makes ANY noise at all while trying to power up(turn on) then your A/C FUSE IS GOOD.
Relay makes a clicking niose when TV is turned on.
Any led that lights up while trying to power up set>>A/C fuse will be good!!!
May 19, 2010 | Sylvania LC420SS8 LCD TV
Ps3 no diplay
if its display settings, you could simply turn off the ps3, so it is on standby, then:
1. hold the ON/OFF button for roughly 5-10 seconds.( or until you hear a second BEEP)
2. let go of it after the second BEEP.
3. your tv should be able to display stuff, but it has reset the display setting, which wont take long for you to do.
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
How do you turn off the beeping sound while using the calculator?
Go to calculator mode. Press the lower of the two silver buttons on the right.
Jan 07, 2010 | Casio New CASIO CA-53W Water Resistant...
Stereo does'nt stay on you turn it on and it just clicks n goes off technics dv290 system
problem with amplifier contact dealer,i have the samne problem with mine,its shows F61 on the diplay and when i check my user manual it states there is a problem with the amplifier
Dec 09, 2009 | Technics SC-DV290 System
Alpine cda-9857r turns display off but is stiil on.
The display can be blacked out on the 9857r. To toggle between display on and display off hold the function button until it beeps.
Feb 27, 2009 | Alpine CDA-9857 CD Player
MW stops after 23 seconds.
PLESE CHECK RELAYS ON PCBOARD .ALSO TRY DISCONNECTING ALL CONNECTIONS TO FRONT PANEL LEAVE IT DISCONNECTED 5MIN THEN RECONNECT AND TRY THE ELECTRONICS SHOULD RESET .HOPE I HELPED BIT OF A WEIRD FAULT
May 09, 2007 | Panasonic NN-S553 1350 Watts Microwave...
Curtis RCD856 CD Shelf System Logo
37 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
NOEL
NOEL
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
