Question about Linksys Wireless-G WUSB54G 802.11g/b
Cannot Communicate from Computer to Computer
I was trying to make wireless HOme&Office Connection and using 2 Wireless -G USB Adapter. Cannot connect to the computers. I uses Windows Xp Home as an operating system and the other uses Windows Vista operating system. I would like these 2 computer set up to communicate our home. Sharing files from one computer to the other at home.
Router, computer1,Lynksys wcg200, recognizes signal. works fine. Adapter, lynksys wireless-G. There is a delay in-between the time I click on a page, during which time i am given a message that the Internet Explorer cannot display the page. The delay lasts approximately 2-3 minutes. Obviously there will always be a delay, but it should never be seen by the human eye. Nanoseconds. Have any ideas what may be causing this? Any solutions?
Posted on Nov 24, 2008
  • virgmrt Nov 24, 2008
    I forgt to add that computer 1 has a windows vista operating system, and computer has windows xp.
    Problem Solver:
  • 14 Answers
A connection from USB adapter directly to USB adapter may or may not be possible. Borrow a wireless router from someone and use it to test supporting connections to your two computers. I think you will find this a much easier way to proceed. Routers can be had for $40 or less. Shop around.
Good Luck
Posted on Nov 20, 2008
Cant get wireless to work on acer aspire ax3400desktop
Is it set up to be wireless? Is there a wireless card installed inside the desktop or are you using a wireless device that you use in one of the usb ports? Do you have a wireless router? Now that we've covered the basic requirements let's see if we can find a solution. Most desktops don't come with the ability to connect wirelessly out of the box. Normally you have to installed a wirelesss device either by using a pci wireless adapter that you istall inside the computer or a usb type adapter that you plug into a usb port. No matter which type you use you should have been given a software disk that contains the driver and the utility that controls the wireless device. You can connect either using the wireless utility software that should be on your desktop or under your programs list. Or you can connect using windows (windows comes with the ability to connect wireless once an adapter is installed) zero config. Normally your wireless utility software will have an option to either let it control your wireless connection or to let windows control the connection. I would try both options if I were you. Make sure you can see your wireless router in the list of available wireless networks. Find your network and click Connect. If it requires a password it will prompt you for it. Now if you notice your connection just continously polling trying to connect that means you put the password in wrong. You will never connect if you don't put the password in exactly right.
Mar 18, 2012 | Acer Aspire AX3400-U2022 PT.SE202.007...
Usb adaptor
you might be knowing about it... but check--
Yes you an can but the purpose of the Wireless Usb adapter is to get the wireless connection from the Router to the PC (Computer)
Connect the Wireless USB Adapter to the usb socket of the computer and install the Drivers with the Help of the CD.
Note to get the wireless connection you need the wireless router connect as well in home network
Jan 24, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
What are the steps to hooking up your xbox 360 wireless network adapter
Plug the wireless USB adapter into the USB port on the back of the Xbox 360 console.
Turn on your Xbox 360 console.
The console will recognize the wireless adapter and will walk you thru the wireless network setup. Be sure to have your WEP key (if encryption is used) for your router before you start this process.
This adapter works well - I am using one and regularly play Modern Warfare 2 with multiple chat sessions. There is no noticable difference between my wired network connection and this wireless network connection.
Happy gaming!
Dec 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
Can't connect through my wireless G network adapter.
Give the default gateway address of your laptop computer in the desktop computer. this will solve your issue.
Sep 02, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Aug 03, 2009 | Computers & Internet
How can I install a wireless usb adapter WG1111....
First put in the cd that came with the wireless USB adapter. Close the auto setup page(we will use windows wireless network manager which works better with windows firewall . Plug in the wireless adapter and the laptop will automatically install the driver. If for some strange reason it asks you to install new found hardware, follow the promts and install manually and select cd and the directory the WG1111 drivers are located. Press ok and wait for install. Restart the computer.
After restart the computer will come up with a caption New Wireless Networks found. Double click on the wireless Icon in the bottom left hand corner. It will open a seperate screen with all wireless connections avaliable to you. Might be 1 or more networks, depending on whether your neighbours have wireless networks. Anyway find your specific wireless network could be for example NetGear, Dlink, or my home network. Click on connect your wireless connection. Another smaller screen will appear with Key in your password twice( WEP key or WPA key)
Key in your key or password twice and apply or ok. It will connect and close screen.
Restart computer!
After restart the computer will pick up your connection automatically and your ready to go on line. If you move your mouse down to the icon with wireless network in bottom left hand corner it will show your wireless connection in a caption stating the connection name and how strogn signal is. Connection complete.
Aug 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wireless problem
that's because your windows wireless is most likely conflicting with the actual wireless device manager..only one can do the job..
Mar 23, 2008 | Computers & Internet
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Linksys Wireless-G WUSB54G 802.11g/b Logo
63 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
