Question about HP LaserJet 1020 Printer
Why is my printer showing a idle status and not printing?
My printer wont print at all it doesnt even with the icon that it is printing. All it showing is a error message that something is wrong with the current printer setup. The only thing i see wrong is that it is showing idle. .... How do i fix that??? its a hp laserjet 1020.
  • nemchugh Feb 02, 2009
    HP OfficeJet 7680 printer, will print configuration page, but not the screen page. Checked status which says "printer idle", and won't print.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
I believe the printer is connected via USB.
Check in device manager if the LJ 1020 printer is listed.
If yes, go to the driver properties > ports tab and Select the appropriate port for the printer
Alternatively, uninstall the full software and reinstall it again from
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=439320&
- Nikhil
Posted on Nov 21, 2008
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Hello guys, i´ll be very
Issue Print jobs are stuck in the print queue (spooler) on a computer running Microsoft Windows connected to the print server. Nothing prints, and the print job in the printer's queue shows a status of Printing . These print jobs cannot be deleted even on the server, and it will not disappear or print until the Print Spooler service is restarted. Solution For Microsoft Windows Server 2003 and Microsoft Windows XP Professional x64 Edition, a fix is available in Microsoft Knowledge Base Article, The Print Spooler service may stop sending print jobs to a printer that uses the standard port monitor on a Windows Server 2003-based computer . Click here to view Microsoft Knowledge Base Article 934885 (http://support.microsoft.com/kb/934885) . To prevent this issue from occurring, disable the bidirectional printing support for each HP printer driver installed. To do this, perform the following steps:
  1. Click Start , point to Settings , click Printers , right-click the icon representing the printer to be modified, and then click Properties .
  2. Click Ports , click to clear the Enable Bidirectional Support check box, and then click OK .
NOTE: Sharing a printer over a network is a feature of Microsoft Windows and not HP printer specific.
Nov 01, 2010 | Office Equipment & Supplies
SUPPLY STATUS
you cann't
just open tha cartridge and mesure how much toner has left inside
after removing the fill cup
utube.png You-Tube video "iMiTopIVMxM" placeholder (do not delete) utube.png
if i help you pls vote
May 05, 2010 | HP LaserJet 1020 Printer
Printer will not print. Not sure if it is related
make sure port settings are correct (ie.. parallel, USB, TCP/IP)
Aug 04, 2009 | Office Equipment & Supplies
As the device is connected wirelessly, make sure there is no interference in wireless communication. Also you can try to set pritner status online by right clicking on printer icon. Also try to  use the cd again and do an add a device.
Jan 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
My printer is in a paused status and i cant unpauseeeit
Hi did u tried to restart the printer if still have the prob please double click on the printer icon comes when u issue a command to the printer check if it shows if there is an error try to cancel the print job which has error and restart the print job if still dosent go on printing just go to controll pannel >fax and printer devices> right click on the lexmark printer icon and remove it and then adda printer put the provided cd with lexmar and reinstall it it should be ok ....
Jan 24, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer Connected but wont print
- go to printers folder then check the status of your printer - if it is offline, right click the icon and select use printer online...
- check if there is pending documents becuase printer wont print if there is pending document in queue- to clear the pending docs. right click the icon and select cancel pending document
- printer OJ 5610 icon should be in ready status, no pending documents, and the icon has a checkmark as as default printer...
Nov 20, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart C4380 All-in-One printer
check the ports first.. make sure that the printer is set as default ( make sure it has the green tick and the status "ready" or "online" on the printer icon in the printers&faxes. and if u want to connect it wirelessly, you have to install it as usb first before changing to wireless........
Jun 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP LaserJet 1020 Printer Logo
14,496 people viewed this question
Ben Johnson
