Question about Black & Decker MFP200 MiniPro Plus 2 Cups Food Processor
Just bought it. makes a high pitched whirling sound. what's wrong?
I'm trying to shred cheese. i followed the step by step instructions and got this sound after shredding a small amount of cheese. i checked to make sure all pieces were in place properly and they appear to be.
  • 1739 Answers
SOURCE: Need a slice/shred hub for the Slice/Shred Disc
Available replacement parts for Black & Decker FP1200 Quick N Easy 8 Cups Food Processor can be found here:
Posted on Mar 26, 2011
0 characters
1 Points
How do i change out the blades?
Unscrew the cap on the underneath side that holds the blade. It will not come off completely. Pull on the cap and the blade assemble will come off ready for the new blade.
Sep 18, 2014 | Lectrix 0401 Saladxpress Food Processor
I need a cheese grater blade for Bc1425
Have you tried calling them for parts?
Mar 24, 2014 | Food Processors
Robot coup makings high pitched sounds and drive shaft seems to lock up
Sounds like the bush is either worn, or the shaft has got rusted.
Oct 31, 2013 | Robot Coupe Food Processors
The robot coupe will stop working periodically during use. The reset button on the bottom pops out after it has been used for a short while. I run a kitchen and it can be very frustrating trying to get...
It is overheating, probably because it is being overworked. Some common problems are overloading the bowl, or forcing too much food into the hopper on top. Once it overheats, it will kick out again rather quickly the next time unless the motor has time to cool. If you are shredding cheese, slow down on the amount of cheese forced into the blade. If you are trying to mix heavy dough you are probably overloading the bowl as well. This machine can't handle over a pound of pizza dough without overheating. The reset button is there to keep from burning the motor out. If you continue to reset and force feed the machine, it will burn the motor out. Good luck, hope this helps.
Sep 11, 2010 | Robot Coupe R2U Ultra Food Processor
My Wolfgang Puck 4 cup continuous flow food processor quit working while shredding cheese. I cleaned it all up and still it doesn't work. Did I blow a fuse? Is it repairable? I've had it for quite some...
Same thing happened to me! Placed a piece of provolone in the feeder, as Wolfgang shows on TSC, and pressed to shred. It turned about 3 times and poof! a flash occurred and the processor died. I believe there is a problem with the wiring due to overload (surprising since it was a small piece). If that's the case, whatever electronics are in this machine are probably fried. I have not brought it to a repair center because the estimate and repair will probably cost more than the machine itself. I also have the rice cooker and it is fantastic! I guess I just got a lemon.
Aug 20, 2010 | Wolfgang Puck BFPR0035CF Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
Sep 12, 2009 | Cuisinart Food Processors
Motor fails to operate - very hit and miss
Make sure you are using the dough blade for dough instead of the regular blade - dough will cause the regular blade/assembly to gum up. This is actually a VERY high quality unit w/ a 20-year motor warranty. I would see if you get better results with the dough blade. Don't give up on it yet.
Dec 14, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Broken part for Technique food processor
PLease check ebay seller churkey123 if these are the same processors. WIll send replacment parts for blade holder for postage!
Dec 09, 2008 | Food Processors
How do I clean the clear plastic parts, I don't know how to seperate them
Try cleaning the parts with olive oil ( let it sit a while to soften the cheese) then with mild dish detergent. The oil softens the cheese and allows the soap to dissolve it.
May 10, 2008 | Cuisinart DLC-10S Pro Classic Food...
Black & Decker MFP200 MiniPro Plus 2 Cups Food Processor Logo
24 people viewed this question
Top Black & Decker Food Processors Experts
Jim Thurston
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
