Question about HP Color LaserJet 4500n Printer
Cannot close middle front drawer
Paper jam, I open the middle front drawer and take out the paper, after that I cannot close the middle front drawer.
You have to take off the left side cover and you see 2 gears close to the middle of printer, those have to be turned to release the clutch for the drawer. The drawer should now slide in.
Posted on Sep 03, 2009
THE PRINTER IS INDICATING A PAPER JAM, THERE IS NO SIGN OF PAPER, THE DRAWERS ARE ALL CLOSED TIGHT
Paper light flashing could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 05, 2010 | Brother HL-2040 Laser Printer
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam --samsung SCX-4828FN
i found that paper jam was in the middle of the mechine. i opened the front door and removed papers.
Sep 17, 2009 | Samsung SCX-4828FN All-In-One Laser...
Paper jam Brother HL-5050
1. Turn off the printer. 2. Remove any paper trays. Inspect them for wrinkled or damaged paper. 3. Also open the back cover of the printer if this model has one. 4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it. 6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside. 8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path. 10. see alternative if the problem is still not solved. alternative : Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 05, 2009 | Brother HL 5050 Laser Printer
Paper drawer is stuck open
Please pull out the tray.
Check if the rear end fence is out of place.
If so, please remove the metal plate with the spring, remove the gear in the middle of the tray (below the metal plate) and reposition correctly in its place the rear and front end fences.
Then try closing the tray.
Good luck and please rate me, thanks.
Jan 27, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Canon printer error 073
The transfer drawer connector or the transfer frame drawer connector is not connected as the front door is closed.
Nov 04, 2008 | Canon imageCLASS 1100 Laser Printer
CD drawer will not open
Most CD's have a small hole in the front of the drawer cover. This hole can be used to open the drawer, straighten out a large paper clip (wire style). About 2" should be enough! Put he paper clip end thru the hole perpendicular to the front (straight in). You will feel resistance at about 1/2" to 1", pressing firmly (don't jam it in), the drawer will start to open as you press the right place, gently pull the drawer open. If something is jammed inside, removal and possible replacement may be required. If you don't feel confident in opening the case, don't!
Oct 20, 2008 | Compaq Presario X1000 Notebook
Misfed jams
First off, does the wheel indicate the proper size paper. Be sure to place close attention to the icon. Second, when you slide the drawer out, in the middle of the right edge, there is a spring loaded pad. Carefully peel the cork off, and rotate it 180 degrees, or you could switch it with the other drawer. Other than that, there might be a small wedge of paper in the lower switch, located in the middle of the paper path, between the paper guides. It may be next to impossible to see unless it is taken apart.
Feb 21, 2008 | Lanier 5222/27 Laser Printer
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
HP Color LaserJet 4500n Printer Logo
239 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
