Question about Kenmore 22422 Top Load Washer
Washing machines
There has been a film breaking lose from the washing machine, that has been getting on the clothes. I'VE BEEN RUN LOW (NO CLOTHES) LOADS and still getting the film. Whats the cure?
    Champion:
  • 203 Answers
Is it a clear film or milky white
Posted on Nov 23, 2008
Am using Daewoo - DWF-750S Top loading washing machine. We have the problem of black film built up at the back of the drum. Am using powder to liquid detergent, the problem still persisted, infact the
Frequently, if you use low temperature washes most of the time, a layer of grease (sounds yukky) builds up in all washing machines. The way around this is to find some clothes (boiler suits or overalls would do) which require high-temperature washes to remove grease and run these through at a high temperature wash for a couple of washes, using both detergent and washing soda (Na2CO3, sodium carbonate). The sodium carbonate will dissolve the grease, both on the clothes and the washing machine.
Jan 31, 2015 | Daewoo Washing Machines
I have a Semi Automatic Whirlpool Sparkle washing machine my question is can i put water in the dryer just to remove soap from the clothes
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
Jul 27, 2014 | Whirlpool Washing Machines
Clothes look drab after washing them.
Is the machine new or old? How long has this been a problem? Has this been occuring slowly or has it started suddenly? Before you give blame to the machine, I suggest you wash your clothes at a laundromat or a friend/relative washing machine to see the results you get. Also, the detergent could be partially at fault especially if you use too little or too much (too much will cause a film to build-up on the clothes that cannot be washed away enough durung rinse). IF AFTER TRYING THESE SUGGESTIONS YOU STILL HAVE THE PROBLEM, open the lid while your Maytag is washing to see if the water level is sufficient and to see if the aggitator is moving; note- you may have to open quickly and check very fast to see if there is aggitation movement because some models stop the washing if you open lid (all models stop the rinse/spin action if you open lid.Goodluck, Macgivor
Nov 09, 2009 | Maytag HAV2557 Top Load Washer
Smelly top loader. It stinks. The clothes don't smell, though. The smell is coming from between the porcelain bowl and the metal exterior. It realy smells terrible. I've run 2 loads of hot water with...
Bacteriological action is becoming more of a problem nowadays due to low temperature washing , the deteregents , wash your clothes well but do not kill off bacteria , this is generally harmless to us but can build up in your machine , giving rise to a smell and sometimes a slime which can get on your washing. A regime of High temperature washes WITH NO CLOTHES IN MACHINE , just a dose of bio-powder every six to eight weeks , may help.
Nov 08, 2009 | Washing Machines
Im getting spots on my clothes when they come out of the wash and they wont wash out. We dont have oily clothes and use the right about of detergent and softner. What would cause the oil looking spots...
Those spots are the results of undissolved soaps built up in the machine over a period of time. Very possibly to much soap is being used on each wash as well. It creates a thick film around the inner drum that eventually breaks away and deposits itself on the clothes in small quantities. To remove, that could be costly, so the next best thing to do would be to run at least 2 hot washes a day without clothes until soap eventually dissolves.It will take a period of time.until particles clear.
Sep 27, 2009 | Kenmore Elite 45986 Front Load Washer
My washing machine is ruining our clothes
The oil from the bearings is leaking. Maybe (not sure about this) the bearings are breaking.
This issue requires major repair, so you may need to contact a service technician. If the appliance still under warranty, contact the manufacturer so they can assist you with the repairs.
Aug 31, 2009 | Washing Machines
Put washing powder in tray ,machine doing wash but leaving large residue of powder
Don't put the powder in the tray. Select you wash cycle, let the water run into the washing machine, then add the powder.The powder should dissolve before you put your clothes inside the machine. Let the washing machine fill up to almost half way and add clothes. This should stop the clothes from getting the residue powder on it.
Mar 23, 2009 | Whirlpool Washing Machines
Washer water level low, clothes come out dry !!
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean.
These washers normally get the clothes almost dry.
Mar 04, 2008 | Frigidaire GLTF1670A Front Load Washer
Facia panel keeps breaking/bleach ruins clother/water level too low and doesn't clean well
Do not use bleach, if you do you will get a bleaching effect,the new machines use less water, do not volume overload machine. mix the load to prevent uneven out of balance spin and check feet are level. Ragrds Advisor
May 05, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
