Question about Midland 1001Z 40-Channels Base CB Radio
NO MODULATION I just purchased a Cobra GTL 142 off of ebay. The radio receives great but does not transmit. in fact when you key the mic, the needle on the transmit meter goes toi the left. My mife is out in the back yard bon the mobil in the truck, and she can't hear anything. WHAT GIVES ?
    Problem Solver:
  • 6 Answers
Have the mic checked
Posted on Jan 08, 2009
Wiring a DM502b mic to a Cobra 142 GTL
  • Factory Microphone Cord Wiring Information:
    (Shield = Mic Ground)
    (White = Mic)
    (Red = PTT Transmit)
    (Blue = PTT Receive)
    (Green = Up)
    (Yellow = Down)
    (Black = Up/Down Common)
    (Orange = B+ (NONE)
Oct 23, 2016 | Cobra Radio Communications
I have cobra ca61 desk mic i need it wired to my cobra 142 gtl home base. the base has 5 pins so i need my mic to be wired for 5 pin... any ideas?
cobra 5 pin to 4 pin adapter on ebay around $5.00
http://www.ebay.com/itm/WORKMAN-C4P5C-CB-RADIO-MICROPHONE-ADAPTER-5-Pin-COBRA-TO-4-Pin-COBRA-/121655850211?hash=item1c5340f4e3:g:e0AAAOxy2YtRsJ8n
Apr 10, 2015 | Cobra Radio Communications
I need to wire a 4 pin to a 5 pin mic turner plus 3 to a cobra 142 GTl
pin#1 audio lead #2 audio shield #3 receive control #4 ground #5 transmit control
Apr 30, 2014 | Cobra Radio Communications
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
Cobra 148 gtl-st wont transmit but receives great
Check first your microphone
• check if TX is engaging when PTT is pushed.
• check for continuity ( mic and cable )
If you have not done these steps,
try it first, or borrow other compatible mic for Cobra 148GTL
from your friends on air.
Jul 28, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Cb is recieving but not trnsmiting
Ah! these and the cobra 2000 had the same board and same problems--
Some will have no transmit audio (check or sub to make sure microphone not the problem) and others no receive audio.
If circuit problem both are caused by a filter cap that opens.
Usually this occurs when radio has not been used for a long period of time.
If you have a schematic for the radio (mine are all out of reach) you will find in the audio circuit a cap (I think it is 220 uf at 10 volts) right near where the volume is controlled that is bad.
The no transmit audio problem is another cap in the mic circuit.
I hope this helps you as it is likely your problem--note if the audio output IC was bad no receive or transmit audio.
shoot me a question by using the make comment if you need further help.
73's
Mar 23, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
No modulation with strong carrier
sounds like your Audio Output went out......not audio chip....may be your voltage regulator also....your voltage regulator IC is heat sunk....do you have a schematic?
Jan 23, 2010 | Cobra Radio Communications
Cobra gtl 148 seems to have no power til i push on mic connecter.
cobra 148 shows no wattage output on external meter but does show good modulation.
Dec 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
No recieve on virgin cobra 142 gtl,
seems to me that the audio ic of the cobra 148gtl brokedue sudden change of voltage from power suplly or flactuation. ta7222p
Jun 07, 2008 | Radio Communications
Midland 1001Z 40-Channels Base CB Radio Logo
215 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
