Question about Canon PIXMA MP160 All-In-One InkJet Printer
Installed new black and color cartridge.
The black ink light flashes and states the cartridge is not compatible the number 5 and E flashes too
  • Canon Master
  • 4,338 Answers
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
Are they Canon ink cartridges?
Remove the cartridges, make sure that the tape is removed , and re-install them. Make sure they are seated correctly.
For future reference , these are the error codes for your printer.
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 18, 2008
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    I replaced the color ink cartridge. Now there is an "E" flashing alternately with a "5". The alarm light is on steadily, and the black ink and color ink lights are flashing. How do I...
    E5 is a Cartridge cannot be recognized error.
    Reinstalling the cartridge could clear the alarm.
    If this does not work,
    Removed both ink cartridges.
    Turn off printer and unplug fron electrical outlet.
    Wait at least 5 minutes.
    This will let the printer reset itself.
    Plug printer back in and turn on.
    Printer will cycle and an E5 will appear.
    Installed back ink cartridges.
    Jan 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
    How to replace the ink cartridge
    1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
    2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
    3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
    4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
    5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
    do rate the solution if it helps
    Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
    Flahing E 5 and lights blinking on black and colored ink
    Hi, the E5 means that:
    not installed[1401],
    cartridge is
    installed[1485],
    not installed
    properly[1687].
    Try with diferrent ink crg., Be sure to use genuine. If that doesnt help, the problem is in printer head, or logic board.
    Hope that helped.
    Jul 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Lost my manual, need to change the ink cartridge, help
    3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
    4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
    5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
    Apr 24, 2010 | Lexmark C533DN InkJet Printer
    Kodak ESP3 installed 2 new cartridges black light
    For that problem kindly try doing the ff:
    * Re-seat the inks both color and black then try printing
    * Re-seat the Printhead of the printer then print again
    * if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
    Hope this will help
    Thanks
    Byron
    Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    HAving trouble printing
    Check and make sure you did buy the right one first.
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
    Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
    CANON MP210 ERROR E15 - INK NEW PRINTER, NEW INK
    Go to this link. In the search window in the center of the screen, type "error e 1 5" and click on the Search button. Select the appropriate error message, then select the answer that says "reseat ink cartridge". You may not have locked the cartridges into place by lifting up until they click.
    Oct 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    Canon PIXMA  MP160 All-In-One InkJet Printer Logo
    790 people viewed this question
    old marine
    old marine
