Question about HP Pavilion a810n (PP164AA) PC Desktop
I cannot eject the disc
I put the disc in and when i pressed eject it wouldn't open
  • HP Master
  • 4,806 Answers
Get a large needle or pin and you will see a little hole near to where the eject button is, if you insert the needle or pin and push it the tray will eject :)
kind regards
Posted on Nov 18, 2008
How do I eject the Dvd
Press the eject button on the top right-hand of the keyboard. Be patient if the disc does not pop out immediately. Try pressing the button a few times or waiting a few seconds and then press the button again. If it doesn't eject, tilt the computer with the disc drive facing down and shake it gently as you press eject.[1]
Drag the disc icon into the trash. If the eject button isn't working, locate the disc icon on your computer's Desktop and drag it to the trash can. The trash can is located on the far right end of the Application Dock on the bottom of the computer screen.
Press and hold "Command" while simultaneously pressing "E."
Find the disc in the Finder. Open the Finder, located on the bottom left of the applications dock. Look on the left-hand side of the pop-up window under "Devices" for the name of the disc in your drive. Locate the eject button directly to the right of the disc name and click on it.
5
Eject the disc through an application if it is not in the Finder. In iTunes or DVD Player, click on the "Controls" drop-down menu located on the top toolbar and click "Eject Disc." You can also open iTunes and click on "Playlists" so that the left side bar pops up. Look for the CD icon with the appropriate name. Click the eject button directly to the left of the CD name.
Jul 11, 2015 | Televison & Video
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Disc stuck in console how to get it out?
I had this problem recently. I got mine out using a thin butter knife. The disc had some sticker residue on it that bonded to the drive when it got hot.
> Carefully ease a long knife (or something very thin) through the felt opening. Stay above the top of the disc (printed side). Then gently hold down on the disc while pressing the eject button.
I wouldn't recommended taking the PS3 apart. Not only will it void the warranty, but it is kinda tricky getting it back together. Besides, this won't really give you better access to the disc because the disc drive is an enclosed metal box.
If there is no (belt rubbing) sound when you press eject, the disc drive probably needs repair/replacement.
May 26, 2012 | Sony Playstation 3 (PS3) Console
My hp pavilion dv6-3025dx disc tray is jammed.
bad drive
replace it
or remove it, and service it.
things do break, and when that happens we replace them.
May 01, 2017 | HEWLETT-PACKARD HP Pavilion dv6-3025dx...
I dont know how to put the cd in
Press the eject button then place the cd in painted side up.
Dec 04, 2011 | Panasonic Home Theater System System
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Disc drive wont open. i pressed the eject button on my keyboard but it makes a clunk sounds but wont open.
This wil show you how to take it apart if that becomes necessary. But try this instead. First hold the eject button down for 5 seconds. I that fails look for a tiny hole near the disc slot. Use a straightened paper clip and push it in the hole firmly. This should eject the disc. Another option is to use firmware to eject the disc. Follow these directions: To eject a disc with Open Firmware commands, follow these steps:
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
  8. Your computer should now start up normally.
  9. Instructions curtorsey eh.mac.ca
Aug 16, 2010 | Apple iMac G4 Desktop
Cd put in drive, is stuck and will not open. Have
Power down.  Now power back up and press the eject button at the top of the keyboard and hold until disc ejects.  If that don't work, then you gonna have to open this thing up and physically take the disc out cause something is blocking it from ejecting.
Nov 16, 2009 | HP Pavilion Media Center a1330n - AMD...
Can't get disc out of tower
Restart the computer, and when computer is starting up keep pressing many times the eject button until disk pops out.
Do this a couple of times
If this does not work you will need to remove the CD/DVD unit and stick a paperclip on the CD eject hole, in the front side of the CD/DVD drive.
Sep 04, 2008 | E-Machines eMachines Desktop PC
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
HP Pavilion a810n (PP164AA) PC Desktop Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
