Question about Gateway Computers & Internet
U heare a noise and the moniter wort turn on - Gateway Computers & Internet
    Novelist:
    Scholar:
  • 84 Answers
Please confirm if the noise is coming from the monitor of from the desktop. If the buzzing noise is coming from the monitor - i suggest to request for a replacement. If not it could be a noise coming from the desktop system fan or from the hard drive.
If you hear like a clicking noise coming from the hard drive you may need to run diagnostics on it to check if the hard drive is failing. check with your computer manufacturer is your system still under warranty for parts replacement.
Keep me posted.
Thanks
Posted on Nov 18, 2008
With homebrewing, what is the difference between extract and all-grain brewing?
Brewing your own beer requires you to boil and make beer with a wort extract. Extract brewing is where you use reconstituted wort to make your own beer. This method is much quicker and requires a lot less equipment than all grain brewing, which involves creating your own wort from the beginning.
It's a great thing to make your own beer from scratch but it's a much more complicated and involved process than brewing your own from wort that you purchases.
Feb 21, 2013 | Crafts & Hobbies
Gateway Computer tower making ringing noise -computer moniter not coming on
See if the Harddrive is making the noise, sscruggs06.
(Computer unplugged from power. Follow Anti-Static Precautions.
I listed them here in a previous solution,
http://www.fixya.com/support/t16277200-check_see_power_supply_working )
Perhaps the Spindle bearings are bad, and Platters are scraping,
http://computer.howstuffworks.com/hard-disk.htm
Post the Model Number in a Comment.
Regards,
joecoolvette
Feb 01, 2013 | Computers & Internet
Turn on my computer, I can hear the fans, no beep noise upon starting. Screen says no signal found. I tried other monitor cables and monitor. No dice.
one of 2 things is happening a) if you have changed the cord and tried other moniters then the display port beit vga or dvi on you computer is broken you will either if you have agraphics card already installed then replace that but if you have no dedicated grapichs card you need to replace the mother bord
B) check your moniter to see if there is a source button if there is then push it to see if the image comes up repeat up to 3 times
ps: if you have a dedicated graphics card look at the back of you computer and if there are 2 different display ports be it dvi or vga (google image the terms "vga port" and "dvi port" to see what they look like) then plug it into the other on to see if the graphics card is broken
May 02, 2011 | Sony VAIO PCV-RZ56G PC Desktop
Fan motor making loud noise. Where can I get a replacement Fan?
Here is a tip I worte about how to buy parts online... it's easy...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Aug 10, 2010 | Refrigerators
NOISE IN MONITOR
Hello
Something you can try is to have a look at the frequency of the monitor. Right click on the desktop, propperties and have a look at the settings.
It is usually the wrong frequency which result in a noise.
Hope this can be helpful.
Kind regards
Andrea
May 24, 2010 | HP W2007 LCD Monitor
Even if i switch on my computer with moniter it doesnt show anything on moniter screen it remains black
Hello. With the computer and monitor OFF, disconnect the signal cable from the video card on your system. Next, turn on the monitor. There should be a bright green box with a pink outline of a video connector inside showing. If there isn't, and the monitor is definitely powered up, then there is an internal problem. If there IS a little green box, etc., the video card in your system is suspect.
  • 1) When turning on the monitor, do you hear the sound of the high voltage initiating?(i.e. you should hear some type of electronic noise like a vibration or crackling of static on the picture tube)
  • 2) If you do hear that high voltage kicking in, it may very well mean that the picture tube is dead and getting a replacement monitor is in your future.
  • 3) If you don't hear the high voltage, quite possibly the transformer that produces it(called a flyback transformer) is defective.
Due to the vast array of inexpensive monitors available, you probably should consider getting a new unit--the cost of a new display will rival the cost of the repair--and you get a fresh warranty to boot. If the picture tube is gone, there's no choice.---Rick
Oct 02, 2009 | Samsung 793S 17" CRT Monitor
My fridge will not cool. I hear it running non stop, there is a trickling water sound, but hardly cools. I had it set at "4" for over 24 hours, and then moved it to the max. At both settings, the freezer...
You have a refrigerant leak sorry I suggest to get a new one because they are not wort to repair then unless you happen to do that for a living. will cost you more to fixed than the fridge wort. :(
Jun 10, 2009 | Haier HSB03 Compact Refrigerator
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
Makes noise
the fan may need to be cleaned or replaced
May 19, 2008 | ViewSonic VA1912wb 19" LCD Monitor
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
